Cofigure Tohatsu 6HP cam rod and shift rod - SailNet Community
post #1 of 1 Old 04-22-2013 Thread Starter
Configure Tohatsu 6HP cam rod and shift rod
When re-assembling after a difficult water pump rebuild, I messed up coordinating the cam rod and shift rod orientation. Both rods are in place and connected at the shift rod joint, but I don't know what gear the system is in currently, nor whether the cam rod is facing in the wrong direction.
What's the best way of coordinating the shift lever, shift rod and cam rod without taking the system apart (again)?
gallilaw is offline
Kanzaki shift fork TheBlackPearl Diesel 1 02-13-2011 04:02 AM
throttle and shift cables wmjr Pacific Seacraft 5 12-17-2010 10:14 PM
Hurth HBW-5 won't shift mwielicki Gear & Maintenance 1 04-17-2010 12:55 AM
Hard to shift Poundsey Gear & Maintenance 0 07-22-2009 01:47 PM
Cal 2-29 shift cable Jbradac Cal 1 05-16-2008 06:21 PM
