Using Bottom Paint on Brass Propeller - Page 2 - SailNet Community
 12Likes
post #11 of 36 Old 04-23-2013
Maine Sail's Avatar
Re: Using Bottom Paint on Brass Propeller
The prop will be bronze, not brass....
While some props are NiBrAl (nibral) most are manganese bronze. The bronze part of manganese bronze is a little misleading because most props contain upwards of 35-40% zinc.. Applying copper bottom paint can destroy them..
This prop was fine for 25 years unpainted. It was painted with a copper bottom paint and in less than one year was dezincified and destroyed.
This manganese bronze prop had also been painted:
This one took the owner over an hour to get all the paint off and only to find out it was totally un-safe for continued use:
Here's another totaled prop due to copper bottom paint:
This one was so dezincified the color was almost uniform. The owner stripped the paint off and a few months later threw a blade:
MedSailor and 73Morgan like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 36 Old 04-23-2013
What Maine says is right. For that reason I make sure that I prep the prop with underwater metal primer prior to any coating of Cu bottom paint. I've used such a system for over 20 years on my expensive max prop and it stays effective for the 2 or sometimes 3 years between haul outs here on the Chesapeake.
lancelot9898 is offline
post #13 of 36 Old 04-23-2013
Tartan 27' owner
CalebD's Avatar
I've been using the Petit Zinc Barnacle Barrier spray paint on my bronze 2 blade prop (a $20 can will last you a number of years). It is not the best protection like MaxProp but works ok; still need to clean barnacles off prop mid-season.
At least with a zinc spray coating the zinc in the bronze seems to be protected from electrolysis.
de-zincafication is a real word and is what MaineSail's photos show.
YMMV
Everybody has one:
CalebD is offline
post #14 of 36 Old 04-23-2013
Tartan 27' owner
CalebD's Avatar
Originally Posted by 73Morgan View Post
Why is it too late?
A brass prop would have disintegrated by now. Bronze, not so much.
Everybody has one:
CalebD is offline
post #15 of 36 Old 04-23-2013
s/v Tiger Lily
dvuyxx's Avatar
I second Pettit Zinc Barnacle Barrier Coat Spray.
Pettit Zinc Coat Barnacle Barrier
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #16 of 36 Old 04-24-2013
Tundra Down
downeast450's Avatar
Me, too!
Down
downeast450 is offline
post #17 of 36 Old 04-24-2013
JimMcGee's Avatar
Sheesh MaineSail, thanks for adding one more thing to my spring to-do list.
I've got the prop off right now to do the cutlass bearing. It was painted with Micron after the application of a primer coat, though I'm not sure what primer the yard used.
I'll take the paint off using a brass wire wheel as the old paint is knicked up and check the condition of the prop.
Is it OK to re-coat with a primer-paint combo as Lancelot is doing or better to just use the Petit barrier coat?
Thanks,
Jim
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #18 of 36 Old 04-24-2013 Thread Starter
Main Sail, thanks, great post.
Bronze has zinc in it, wow, that explains the electrolysis concerns.
Scary bunch of pictures, internal damage. I will change my ways, hope it is not to late.
You just indirectly explained why it is a good idea to have a zinc on the prop shaft. Been changing the zinc on the prop shaft every year. That probably helped a little??
73Morgan is offline
post #19 of 36 Old 04-24-2013
casey1999's Avatar
Why are props not made from silicon bronze?
Price looks to be about the same and then there would not be the concern of getting dezincified and destroyed.
Silicon Bronze C65500 is comprised of 95% Copper, with 4% Silicon and 1% Manganese to combine high strength and good hot and cold formability with excellent welding characteristics. Additionally, 65500 exhibits good resistance to corrosion by brine and sulfite solutions, non-oxidizing inorganic acids, alkalis, and other mixtures. The mechanical and chemical properties of Silicon Bronze 65500 are similar to those of stainless steels.
Silicon Bronzes are commonly used in the pump & valve component, fastener, piston ring, and marine hardware industries.
casey1999 is offline
post #20 of 36 Old 04-26-2013
s/v Tiger Lily
dvuyxx's Avatar
I believe the Pettit instructions are to apply it to clean bare metal (rub down with MEK before).
Severna Park, MD
dvuyxx is offline
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
bottom paint blakeyoung Gear & Maintenance 7 05-02-2013 07:06 AM
Paint thinner for soft ablative bottom paint jameswilson29 Gear & Maintenance 7 11-26-2012 12:56 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Bottom paint on propeller? aphil138 Gear & Maintenance 17 01-09-2007 05:29 PM
