Leaking Strut - SailNet Community
Blogs
Old 06-09-2004
jwlthf is on a distinguished road
Leaking Strut
I have a 2001 Catalina 310. I hauled it out for bottom paint and to replace thge cutlass bearing and found a little moisture seaping around the strut. (the strut seems to be very tight, I could lean into it and it didn''t seem loose) The moisture meter read 100% right beside the strut. The head of one of four bolts which I can access inside the boat had a little rust on it. It is fiberglassed tight to the strut all around on the outside. The yard told me to scrape out a little fiberglass around the strut, fill it with 5200 and it would be ok for another season. When I haul it next time I should knock the bolts through, drill holes to let it dry out and reattach everything. Has anyone else had this problem, is it dangerous and how expensive was it to have fixed. I also have vibration when in gear. More at low rpm''s and less at higher rpm. any advice would be appreciated.
Where to get a prop shaft and strut?? john232 Gear & Maintenance 4 01-06-2004 11:26 PM
Rebedding leaking lexan ports jhoover3468 General Discussion (sailing related) 12 12-01-2003 10:17 PM
leaking gas tanks LarryLevine Gear & Maintenance 3 04-28-2003 11:37 AM
Mirage 26 strut eda0457 Gear & Maintenance 0 04-07-2001 09:41 AM
Strut for Kirby 30 kmn General Discussion (sailing related) 1 03-24-2001 01:38 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
