Mast wiring tip needed. - SailNet Community
 5Likes
post #1 of 35 Old 04-23-2013 Thread Starter
First String
I know I'm new to boat wireing.
I need help.
I have a C&C 30 mk1. The mast has a steamer light and 2 spreader lights. At the very top there is a coax and a transducer cable.
The spreader lights and the Steamer light are not hooked up? They were not hooked up when I purchased the boat.
The only thing is I dont know how to wire them . Thwew is a negitive buss onder the seat where the light could be hooked up but there is no positave buss? Do i hace to run a hot wire all the way back the the switch on the cabin wall?
ltgoshen is offline
post #2 of 35 Old 04-23-2013
Re: Mast wiring tip needed.
Something sounds way to easy here. I would ask this first......Is there a reason that they disconnected the wiring in the first place?? Is there a short somewhere?
benesailor is offline
post #3 of 35 Old 04-23-2013
Didn't mean to sound like an a$$. I think you are on the right track.
post #4 of 35 Old 04-23-2013 Thread Starter
First String
Sorry I know photos help Keep your eye on the Yellow Green White/red and the RED and Black.
Here is were they end up. the look to be a positive right?
The wires coming out of the bottom of the mast.
And yes I was thinking there was a problem as well? But not sure how to start. I am useto auto and house power not boat. It seams to work diff???
ltgoshen is offline
post #5 of 35 Old 04-23-2013
Junior member, rest old
msmith10's Avatar
Yes, you have to run the hot wire from the fuse panel. There is no positive buss-- if there were such a thing you'd need to wire a switch after the bus to a convenient spot anyway.
On my boat the negative buss is under the forward dinette cushion, to port of the mast step. There is a fuse panel above the galley sink which has a "steaming light" fused switch. Positive goes from there to a connector under the dinette. This connector is actually a "segmented" bus bar which allows multiple separately fused circuits to be connected in one location. This is convenient to have under the dinette so all 12V mast connections can be connected in one area. I also run my bilge pumps to that bus.
If you find a similar separated-circuit bus bar in your dinette, just test each circuit while you try switches at your fuse panel. I suspect that it's already wired but may be unused for whatever reason.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #6 of 35 Old 04-23-2013
msmith10's Avatar
My last post was before you posted the photo. Yes, everything is there. The bus in your bottom photo is positive. Each screw should be a separate circuit. One of those wires on the left side of the bus is your steaming light. I can't remember which one and my wiring diagram is on the boat, but just put a voltmeter on each connector and hit your steaming light switch and you'll find it.
How is your mast wiring? If you need to replace it, I'd recommend putting conduit in the mast. The absence of wires slapping around inside the mast is worth the work.
Mark Smith
msmith10 is offline
post #7 of 35 Old 04-23-2013 Thread Starter
First String
Originally Posted by msmith10 View Post
My How is your mast wiring? If you need to replace it, I'd recommend putting conduit in the mast. The absence of wires slapping around inside the mast is worth the work.
They seam to be in good repair on the lower end/
ltgoshen is offline
post #8 of 35 Old 04-23-2013
rugosa's Avatar
C & C standard wiring from owner's manual -
Yellow - spreader light
White w/red - mast head light
Green - bow light (about half way up mast)
Red - fordeck light
ALL ABOVE RUN BACK TO PANEL
Black - ground - connects to negative buss
Sail on
rugosa is offline
post #9 of 35 Old 04-23-2013
msmith10's Avatar
Now you're good to go.
Mark Smith
msmith10 is offline
post #10 of 35 Old 04-23-2013 Thread Starter
First String
So run one wire to the correct buss for the switch. then use a but connector and run a new wire back to the other pole on the same switch?
Sounds simple enough. I wonder why the wires are not there now?
ltgoshen is offline
Wiring diagram needed old-sailer C & C 1 05-28-2012 07:42 AM
Raymarine ST60+ Wiring pinout needed. old-sailer Gear & Maintenance 1 05-14-2012 03:00 AM
Where does your mast wiring exit the mast? downeast450 Electrical Systems 0 02-27-2012 08:43 AM
Mast Wiring CLucas Gear & Maintenance 8 08-25-2010 11:06 AM
Wiring help needed SpeedAgent Gear & Maintenance 11 07-16-2009 11:41 AM
