Open or closed seacock? - SailNet Community
 1Likes
post #1 of 24 Old 04-24-2013 Thread Starter
Am I correct in my understanding that you can tell whether a seacock is open or closed by whether or not the handle is parallel to the hose? That it doesn't have anything to do with whether the handle is parallel to the "T" in the seacock itself?
So in these pictures below, am I correct in my guess as to whether they are open or closed?
Open:
Closed:
Open:
Open:
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #2 of 24 Old 04-24-2013
ronspiker's Avatar
Re: Open or closed seacock?
Your observations are correct.
ronspiker is offline
post #3 of 24 Old 04-24-2013
kunkwriter's Avatar
I concur, you are correct.
kunkwriter is offline
post #4 of 24 Old 04-24-2013
Captn D
Though I'm thinking the handle on the Blacke seaccks (circa 1967) on the Moody Halberdier I had could be placed on the plug (VALVE STEM) in four different positions. The head of the plug for the handle was square. The sure sign was the "arrow" on the plug head indicating the open side and if the sink drained or not!
Halberdier is offline
post #5 of 24 Old 04-24-2013
Usually you can tell by the handle orientation as you suggest... but I'm wondering why the 'plugged' one was left 'open'....????
Faster is offline
post #6 of 24 Old 04-24-2013
chef2sail's Avatar
Yes me too!!!!!!
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #7 of 24 Old 04-24-2013
Also noticed in a few of the pixs some green goo that appears to be leaking..is that from servicing the thru haul seacocks? Also noticed no green wire bonding.. Yes I know there are different theories about bonding vs. non bonding thru hauls..
aa3jy is offline
post #8 of 24 Old 04-24-2013 Thread Starter
I was wondering about the open plugged one myself. We've only had her for a week so I really don't know. Any suggestions as to how to handle this? She's on the hard so perhaps we can test it?
As for the green goo. I thought it was just from servicing them. The prior owner seemed very diligent in all of his maintenance (both annual and periodic), he's remaining at the same marina, and he's offered to make himself available for questions (an offer I definitely don't want to abuse), so I wasn't too worried about it. Should I be?
Thanks.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #9 of 24 Old 04-24-2013
Wipe up the gooo and if it's makes it's self present again then the seacock maybe leaking.. I assume the boat is in the water?
aa3jy is offline
post #10 of 24 Old 04-24-2013 Thread Starter
Actually it's still on the hard. I assumed the seacock was open because of that (although I can't remember what is connected to the closed seacock).
I'll try to wipe up the goo (if it's not hardened) for neatness if nothing else.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
Opinions wanted - fabric vs vinyl, open vs closed cell foam jarcher Gear & Maintenance 20 04-25-2009 11:45 AM
Seacocks Open or Closed when Away from Boat DrB General Discussion (sailing related) 22 05-01-2008 11:45 PM
Closed vs Open body turn buckles Wayne25 Gear & Maintenance 8 12-06-2007 12:29 PM
What's open, closed for Memorial Day (Seattle Times) NewsReader News Feeds 0 05-28-2006 05:15 AM
Open vs Closed turnbuckle bodies bsfree Gear & Maintenance 4 04-24-2002 10:25 AM
