Rebuild head, or replace, and with what? - Page 3 - SailNet Community
 7Likes
post #21 of 29 Old 04-25-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Re: Rebuild head, or replace, and with what?
I agree with the idea of knowing how to fix it being a good thing. But a) I'm not likely to be taking extended cruises any time soon, and b) I have a lot of other, more valuable ways to spend my time at this point. If we were talking 20 minutes to replace and 30-35 to rebuild, then ok. But if this will be an hours-long process, I'd rather replace.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #22 of 29 Old 04-25-2013
turophile
I recently rebuilt a similar looking Groco, and the rebuild took about 10-15 minutes and really wasn't that messy/stinky. Flush a bunch of fresh water (or something stronger) undo about 4 bolts, replace a bunch of gaskets, o-rings, joker valve, etc, grease the pump, put it all back together, and wash up. The kit was more expensive than I thought it should be, but much cheaper than a similar quality head. I can't imagine replacing the head would be easier or less messy or more cost effective than what I experienced. I hear the several people saying the cheapo Jabisco works fine, but I personally would rather have a rebuilt ~$400 head that I already own, than a new ~$150 head that gets questionable reviews.
bristol299bob likes this.
mr_f is offline
post #23 of 29 Old 04-25-2013
I had terrible luck rebuilding a Jabsco, but two new replacement units on two different boats worked out great...both units worked fine for fairly light weekend use. I like the Raritan PH II unit we have currently, but it will be soon due for a rebuild. While I like the idea of repair versus replace, my expereince with a rebuild was less than satisfactory. The Raritan we have was rebuilt a couple years ago, but the pump isn't doing as good a job as it should. I'me not thinking to rebuild it again.
1983 Lippincott 30 s/v Red Horizon
Regent Point Marina Topping, VA
RedHorizon is offline
post #24 of 29 Old 04-25-2013
Group9's Avatar
I think the main reason I go with a new head almost every time is that a working head is the one thing by significant other absolutely demands on our boat.
I am not going to try and calm her displeasure when my repair doesn't work, by saying, "I really thought I could fix it, honey."
bristol299bob and jimgo like this.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #25 of 29 Old 04-25-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Group9, I think you've just hit on the winning argument. Not so much the "Admiral demands it" part, but the idea of working from a known-good head so that, when something breaks, I will have a better sense of where the problem(s) are. At this time, I'm not sure WHERE the problems are (if any) or how to fix them.
I'm going to visit the boat on Sunday, and since I'll be nearby, I'll head over to the Annapolis boat show, too. Who knows, maybe I'll find a REALLY good deal on a head.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #26 of 29 Old 04-25-2013
Commodore
n8kraft's Avatar
Jim,
I'm a fan of rebuilding the head and having a rebuild kit aboard so you know you can make it work later when you're in that lovely secluded anchorage and the crapper stops working you already have an idea how it goes together.
Regardless of whether you will rebuild or replace you need to completely clear your blackwater hose from the toilet. The best way I've found is to go to the pumpout dock and completely pump and rinse out the holding tank. Next flush the head with plenty of freshwater to completely purge any blackwater from the hose, then switch to dry. Have someone else help by either pumping the hose dry or holding the pumpout suction hose for you. There will be barely any effluent that comes out of the hose to the holding tank!
Enjoy this project.
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #27 of 29 Old 04-25-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
Thanks, the instructions are appreciated! I'm not sure, however, that I'd classify this as an "enjoyable" project!
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #28 of 29 Old 04-26-2013
Originally Posted by n8kraft View Post
......Next flush the head with plenty of freshwater to completely purge any blackwater from the hose, then switch to dry. ....
Ironically, one should always flush enough water to completely purge black water after each use. Most don't and it's the biggest reason for odor. In particular, there is typically a vent loop that waste must be pumped up to, before it goes to a holding tank or a thru hull. It will never empty, so one must pump enough that only clean water remains in it.
jimgo likes this.
Jeanneau 54DS
Minnewaska is offline
post #29 of 29 Old 04-26-2013 Thread Starter
Asleep at the wheel
jimgo's Avatar
For anyone following this thread, WestMarine just published their weekly sale catalog:
West Marine eCatalogs
The Jabsco Twist'n'Lock is discounted from $195 list to $160, and then there's a $25 rebate.
I'm going to look at my head when I'm there on Sunday and see which model Groco I have; if it's one of the better quality, metal ones, then I'll rebuild. Otherwise, at $135, the Jabsco could fit the bill nicely. I'm still planning to walk the boat show in Annapolis to see if I can get a good deal on a Raritan PHC, too, but the Jabsco could be interesting.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
$6,600 to rebuild Atomic 4? replace/rebuild simmonct Atomic 4 73 03-13-2017 11:49 AM
Older Yanmar.. rebuild? replace? or?... chrisncate Diesel 274 04-06-2011 11:26 AM
Replace vs Rebuild? chtaylor Atomic 4 12 01-22-2009 10:08 PM
Rebuild or Replace wcshedd Gear & Maintenance 2 05-21-2003 09:52 AM
REBUILD or REPLACE bombero Gear & Maintenance 0 11-22-2000 05:55 AM
