-   -   Attaching hardware to spars. (http://www.sailnet.com/forums/gear-maintenance/98809-attaching-hardware-spars.html)
utchuckd 04-24-2013 10:12 AM
A couple of projects on my to do list are adding lazy jacks and re-rig a reefing system. What's the best way to add needed hardware to the mast and boom?
Also, how high up the mast should the lazy jacks be mounted? Most systems I see have them up around the spreaders, do they really need to be that high?
bristol299bob 04-24-2013 11:00 AM
Re: Attaching hardware to spars.
regarding adding hardware to mast and boom: I'd drill, tap, apply tefgel and use SS machine screw. (assuming the mast and boom wall thickness is decent)
SlowButSteady 04-24-2013 01:17 PM
On an O'Day 23? I wouldn't bother with the lazy-jacks. Your main is small enough to make the lazy-jacks far more trouble than they're worth. I took them off of my Cal 2-27 (with about 50-60% more sail area on the main than an O'Day 23) for just that reason.
heelangle 04-24-2013 01:57 PM
Ditto, on the need for lazy jacks on your boat. Just more lines to get in the way. Handling and stowing that main is an easy one person job.
I agree with the previous post on attaching mast hardware. Need to do that myself soon.
zz4gta 04-24-2013 02:07 PM
Chances are the wall thickness will not be great. I'd opt for rivets, or if possible, through bolting may be an option and is by far the strongest.
I've seen a lot of hardware pull out of a mast that was drilled and tapped.
