What is this, can I hook a block to it? - SailNet Community
post #1 of 9 Old 04-24-2013 Thread Starter
I have this weird T-shaped thing (with handlebars) near the front of my bow just after my furling gear (see photos).
Can anyone tell me what this is for? I was hoping I could figure a way to attach a block to it (via a strop?) to control the tackline (downhaul?) for a future asymmetric spin.
If that won't work, what would you recommend for attaching a block to for the tackline (given the photos above)?
I'd really appreciate any thoughts or guidance!
Reefpoints is offline
post #2 of 9 Old 04-24-2013
Re: What is this, can I hook a block to it?
It's a pair of tack hooks.. Meant to be used so you can quickly and easily hook in the tack of a headsail, and be able to connect a second before you dropped the first. With the curler you have now the are kind of redundant. You could attach a block but how to keep the block secure will be an issue.
Maybe use some kind of lashing over both hooks with the block centered between them..
Faster is offline
post #3 of 9 Old 04-24-2013
One of None
deniseO30's Avatar
When your boat had hank on head sail/s that is where the bottom corner (the tack) grommet hooks on.
My last project!
deniseO30 is offline
post #4 of 9 Old 04-25-2013 Thread Starter
That makes sense - thank you!
post #5 of 9 Old 04-25-2013
Dog Ship's Avatar
Drill a hole through it large enough for a shackle.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #6 of 9 Old 04-25-2013
rbrasi's Avatar
It could also be a place to hook your jib sheets when you fly your spin to get them out of the way. I use a small bungee for that.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #7 of 9 Old 04-25-2013
The tack hooks are frequently used to change jibs when racing. Note that your head foil has two slots for the bolt ropes of jibs. Normally you set up the tack of the jib in the same side (port or starboard) that you'll put the boltrope.
To change the jib, run the second jib up the vacant grove in the foil and affix the tack to the vacant tack hook. Normally you do this by putting the new jib up on the windward side, therefore, if the old jib is in the port groove you'd, when on starboard tack, raise the new jib in the starboard grove and affix the tack to the starboard horn. Once you get the new jib up and a sheet or sheets affixed, you tack, trim in the new jib, and drop the old jib inside of the new jib.
It's straightforward but is sometimes physically demanding. That's why the skipper buys the first beer.
Hudsonian is offline
post #8 of 9 Old 04-25-2013
I don't discuss my member
zz4gta's Avatar
Yes
Merit 25 # 764 "Audrey"
zz4gta is offline
post #9 of 9 Old 04-25-2013
Is that a san juan 7.7? I have the exact same piece on my 7.7, I actually use them as I don't have furling.
jeffzee is offline
Reeving a fiddle block with becket and single block? dsimon General Discussion (sailing related) 4 06-26-2012 12:05 AM
hi from the hook chrisncate General Discussion (sailing related) 2 07-18-2010 07:25 AM
The scent of Block Island (Block Island Times) NewsReader News Feeds 0 09-15-2006 10:15 PM
Rigging a block-to-block boom traveler? GC20Squid General Discussion (sailing related) 3 03-23-2006 09:31 PM
How do you hook up at a mooring? Gidget2004 Learning to Sail 4 05-28-2004 07:52 AM
