Traveler setup? - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 04-26-2013
I don't discuss my member
zz4gta's Avatar
Re: Traveler setup?
You want to do something like this
Judging by the 3:1 mainsheet I'm guessing this is a pretty small boat? I use a 2:1 traveler setup like the one above on my 25 footer and it works well.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #12 of 19 Old 04-26-2013
Old as Dirt!
svHyLyte's Avatar
Re: Traveler setup?
Originally Posted by rbyham View Post
How does this traveler work? It is currently one continuous line but I cannot seem to stop and control it where I want to. Should it be two separate lines or different threading? Name is Amioto... Thanks
We have the same traveler system and although the photo is poor it appears that the control lines are not lead properly. The control lines are intended to be independent not continuous. I suspect you will find a hole in the vertical portion of the track near the end stops on either end. These are the points where your control lines originate. The control line should be passed through this hole, from the mast side to aft and a stopper knot made. The running end of the line then runs to and through the lower sheave on the near side of the traveler car, back along the aft side of the track to and through the sheave on the inboard side of the end stop, then back along the front of the track to and through the upper sheave on the near side of the traveler car and then back to and through the outboard sheave and cam cleats on the end stop. The control lines on the opposite side of the traveler are run in a similar fashion. One can actually use a single line for both control lines as long as one leaves a sufficient length of line in a bight between the cam cleats on either end of the track so that, when necessary, say broad reaching, the traveler can side from one end of the track to the other when tacking. The continuous line, or simply tying the ends of the control lines together, allows one to free the line from the opposing cam cleats when one is on the off end of the traveler in a tack. As a practical matter, this type traveler is not terrific in the given application as tension must be applied to the control lines horizontally. In a cockpit, unless the traveler is positioned waist high or better, one is generally better off with control lines that require an upward pull to free or adjust.
FWIW...
svHyLyte is offline
post #13 of 19 Old 04-26-2013
Re: Traveler setup?
By enlarging you picture It seems the rope is threaded in a strange way.
He way to thread this depends on the number of sheaves on the end of the track and on the traveller.
Take the whole rope off again.
Start by threading half of the rope trough the cleat on one side (Port)
Take the end of the rope on the aft side of the cleat.
Thread this end through the port upper sheave on you traveller (from aft).
Take same end to port again - if you have a sheave sitting below the cleat thread the rope for to aft through this sheave (if not there should be a place there to make the end fast).
Continue until there are no more sheaves on the end of the track and the port side of traveller. There should be be a point somewhere to make the end fast.
Repeat on starboard side.
You don't need to make this an endless system.
knuterikt is offline
post #14 of 19 Old 04-27-2013
Re: Traveler setup?
RB,
My guess is that it's just not threaded correctly. The ends of the control line should land at the traveller block leaving the continuous line (loop) as the control. The end blocks look like they have built in cam cleats, Do these pop open when you pull the line in one direction (towards the center) and jam when you pull outboard? Was this threaded like this when you bought the boat or maybe the PO just put the line back on to show the boat and did it wrong.
John
jfdubu is offline
post #15 of 19 Old 04-27-2013 Thread Starter
rbyham's Avatar
Re: Traveler setup?
Does this picture help? I can see how to make it two sheets by starting with bowling at either car or clam end. It just concerns me that when purchased it was continuous.
rbyham is offline
post #16 of 19 Old 04-27-2013
utchuckd's Avatar
Re: Traveler setup?
Maybe instead of going all the way around the far side of the car from agiven side it should jsut go around the block on that side and back?
Donnie Harris
1980 O'Day 23
utchuckd is offline
post #17 of 19 Old 04-27-2013
4KSB driver.
SHNOOL's Avatar
Dock
Re: Traveler setup?
I have never seen that done... It looks like the lines go around the opposite sides of the traveler. utchuckd has the best example of how the lines should be run. ignore the mainsheet in that, and focus JUST on the traveler.
If you take the ends on the left and the right, and tie them together, you have a "continuous line," that'd be the only way to properly make that continuous. What I am seeing with what you have now is NOT continuous, as you have a defined left and right termination.
But what gets me is how the left side wraps around the traveler car on the right side. Maybe it's a funky picture I dunno.
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #18 of 19 Old 04-27-2013
fallard's Avatar
Re: Traveler setup?
An earlier poster captured what appears to be the case on the OP's recent photo: The lines exit through what appear to be cam cleats and each end of the traveler.
If the cleats are working, that would take care of immobilizing the car. If there is too much friction in the cam cleats, there may not be enough pressure for the cams to "bite" on the line.
fallard is offline
post #19 of 19 Old 04-29-2013
Re: Traveler setup?
Pull out the traveler control lines and run them as close as you can to the illustration in Post 16 above.. You may end up with one less part, but the way that's all reeved now is difficult to see and is apparently not working.. I suspect that the cleats are holding fine but the line is reeved in such a way as to allow the car to slide back and forth with the control lines fixed.
The picture isn't clear enough, but starting over should do the trick.
Faster is online now
J-29 Spinnaker Setup Ryan Heaslip Racing 13 08-21-2015 11:53 PM
Jib sheets setup davidpm Gear & Maintenance 1 04-15-2012 09:31 PM
Mainsheet/Traveler Bimini setup LASWACK General Discussion (sailing related) 8 02-21-2011 09:47 AM
How to setup the cunningham - J24 Drake76 Learning to Sail 3 05-30-2010 10:15 PM
Head Setup? 1970Columbia34 Gear & Maintenance 6 05-09-2007 05:25 PM
