Look at this bleed through... - Page 2 - SailNet Community
 5Likes
post #11 of 20 Old 04-25-2013 Thread Starter
blutoyz's Avatar
Re: Look at this bleed through...
I haven't pulled a keel bolt but theu look really clean ...incredibly clean for 30+ years I must say (new and shiny). Inside of the sump is fine, the wood is a little wet but the glass is clean.
That through hull is a drain and I have the plug for it.
The bilge pup is screww to an epoxied plywood base but I will look closer. It is aft of the worst "drips". More in the area with the discoloration.
blutoyz is offline
post #12 of 20 Old 04-25-2013
Aspiring to be a Mexican
sww914's Avatar
The tops of the keel bolts can look nice and clean but it's the part below the nut & washer (or head, as the case may be) that corrodes and breaks. Crevice corrosion.
Minnewaska and SloopJonB like this.
sww914 is offline
post #13 of 20 Old 04-25-2013
Senior Moment Member
SloopJonB's Avatar
Exactly right. If you have wetness in the bilge the chances are that the bolts are going bad where they pass through the hull, not under the nuts.
The only way to be sure is to drop the keel.
SloopJonB is online now
post #14 of 20 Old 04-26-2013
I just can't tell from the pic, but it has the appearance of rust bleeding through the paint. What material is immediately behind the circles at the top of the streaks? If steel, its probably a no-brainer. Just grind down, epoxy coat and then reapply the anti-foulant. Pretty normal stuff, not a big deal. Although, its pretty evident that the keel joint is below the bleed through, so I'm not sure what material you have there.
Whether the keel bolts are any good is another story altogether, but I'm not seeing how they would manifest themselves like those pics, even if they were bad.
JimMcGee and bljones like this.
Jeanneau 54DS
Minnewaska is offline
post #15 of 20 Old 04-26-2013 Thread Starter
blutoyz's Avatar
Well...no one wrote
OH MY GOD...your boat is nothing but salvage now!!!!
That is a good thing so I will take a close look once more, clean it up, and paint it for launch. The PO never had any leaks and I am not planning any bluewater cruising so it will be fine I am sure.
As you can tell I wasn't expecting a perfect boat for my whopping $3k
Thanks for checking out the pics and I will post if I find the actual cause today.
Bill
blutoyz is offline
post #16 of 20 Old 04-27-2013
TQA
Bombay Explorer 44
TQA's Avatar
If the bilge is not filling up when it is in the water I would slap on some fresh AF and go sailing.
TQA is online now
post #17 of 20 Old 04-28-2013 Thread Starter
blutoyz's Avatar
I ground it back to get the rest of the water that worked it's way through out and will fill the small areas with some resin. It looks like some water worked into the joint over the winter through the keel bolts. If it was a big $$$ boat I would drop the keel and have a look-see but it is not so I will not.
One of the old-timers at the marina said to use bondo with glass mixed in.
blutoyz is offline
post #18 of 20 Old 04-28-2013
bljones's Avatar
Chances are the keel is sealed to the boat wiht a flexible caulk, so simply slathering some bondo over it isn't going to do much good. Clean up the joint, and tighten up your keelbolts.
It's 5 o'clock somewhere:
bljones is offline
post #19 of 20 Old 04-28-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
I would definatly think about removing a keelbolt or two and seeing that lies beneath what you can see.
It might also be a good time to consider taking that area of the bottom down to the gelcoat to see what kinds of repairs have been made there in the past
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #20 of 20 Old 04-29-2013 Thread Starter
blutoyz's Avatar
There were no previous repairs. I took it down to dry it out, mixed some glass powder from a recent cut(speaker install) with marine epoxy and filled. It was only two quarter sized spots. Next week I will sand and coat with AF paint.
It was very minor once I investigated it further. I think that they were acually a couple of minor hull blisters after a closer look. They have nothing to do with the keel joint other than proximity it seems.
Thanks for all the ideas
blutoyz is offline
Volvo MD2010 won't bleed talbot Diesel 5 08-10-2011 01:38 PM
Where to bleed air?! jimmy Diesel 17 09-25-2010 04:18 AM
Replacing Bleed Screw? rjg23 Gear & Maintenance 5 05-31-2010 09:15 AM
How to bleed hydraulic steering? I33 Gear & Maintenance 4 01-31-2009 09:13 AM
Racor bleed question 7tiger7 Gear & Maintenance 1 07-05-2007 11:53 PM
