Look at this bleed through... - SailNet Community
 5Likes
post #1 of 20 Old 04-25-2013 Thread Starter
blutoyz's Avatar
...and give me your opinions.
Keep in mind that this is a cheap starter boat. Strip, barrier coat, and bottom paint two seasons ago. Power wash when pulled last season. I was planning on a coat of fresh paint after a wipe down with denatured alchohol.
I saw this "bleed through" and was wondering if I should do something more before I just paint it up and splash.
what say you?
blutoyz is offline
post #2 of 20 Old 04-25-2013
Senior Moment Member
SloopJonB's Avatar
Re: Look at this bleed through...
I'd want to know what's causing those two streaks.
Close ups?
Also, I wouldn't be satisfied with the state of that keel/hull joint but I'm pretty OCD about my bottoms.
sww914 likes this.
SloopJonB is offline
post #3 of 20 Old 04-25-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
I would like to know what is there in the hull. If you notice the thru hull forward of those marks is at the same level
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #4 of 20 Old 04-25-2013
timangiel's Avatar
why dont you tell us the model and year of the boat, maybe someone else with the same boat has had the same issue.
timangiel is offline
post #5 of 20 Old 04-25-2013 Thread Starter
blutoyz's Avatar
That is the winter plug for driain on the hard
blutoyz is offline
post #6 of 20 Old 04-25-2013 Thread Starter
blutoyz's Avatar
1981 US yacht 27
blutoyz is offline
post #7 of 20 Old 04-25-2013 Thread Starter
blutoyz's Avatar
Close ups?
It is an old boat and the keel bolts look good inside. The streaks seem to be dirty water marks. I will try to blow it up and upload.
blutoyz is offline
post #8 of 20 Old 04-25-2013 Thread Starter
blutoyz's Avatar
I uploaded a larger pic and cropped it:
blutoyz is offline
post #9 of 20 Old 04-25-2013
tommays's Avatar
IMHP fairly normal line between the keel and keel sump that was most likely always that way
What looks to a through-hull fitting in the sump is a bit odd unless it is a knot meter ?
My big concern would be how the inside of the sump and the nut/bolts look
I would look for owners groups for the hull and see if it has know problems as i found out about all the Cal warts that way and was able to make a much more informed decision
1981 US yacht 27
Lots of info about those warts
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #10 of 20 Old 04-25-2013
We can copy the photo and blow it up..I did but it doesn't really tell us any more than what we can see here.
I'm wondering. Do you have a bilge pump in that location that has been screwed in to the bilge? Looks like something's bleeding through aft too. Anything mechanically attached/fastened inside the bilge in those locations?
The forward thru hull is the Garboard drain plug. I'm assuming
tempest is offline
Volvo MD2010 won't bleed talbot Diesel 5 08-10-2011 01:38 PM
Where to bleed air?! jimmy Diesel 17 09-25-2010 04:18 AM
Replacing Bleed Screw? rjg23 Gear & Maintenance 5 05-31-2010 09:15 AM
How to bleed hydraulic steering? I33 Gear & Maintenance 4 01-31-2009 09:13 AM
Racor bleed question 7tiger7 Gear & Maintenance 1 07-05-2007 11:53 PM
