Teak Deck Replacement with Nonskid - Page 2 - SailNet Community
 11Likes
post #11 of 50 Old 04-28-2013 Thread Starter
Commodore
n8kraft's Avatar
Re: Teak Deck Replacement with Nonskid
Got most of the cockpit teak and hardware removed today. Tomorrow I'll be cleaning up all the stuff we removed today.
Transom shot
Great help today from Jaime, Natalie and Eric! Tomorrow I hope to fill a lot of new screw holes.
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #12 of 50 Old 04-30-2013 Thread Starter
Commodore
n8kraft's Avatar
Got the teak all off the cockpit and lots of screw holes filled with epoxy. Now it's just what to do with the quarterdeck area. The deck feels solid, but my moisture meter says it's wet. I'm letting it dry out and will see if the wood still stays solid.
n8kraft is offline
post #13 of 50 Old 04-30-2013
Asleep at the wheel
jimgo's Avatar
Nice work!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #14 of 50 Old 05-01-2013 Thread Starter
Commodore
n8kraft's Avatar
Thanks. I'm making a trip to WestMarine to get some more epoxy and fairing filler. Then I'll be working on the deck above the transom and quarterdeck. My next big issue will be working with the coaming that's left around the cockpit from where I removed the teak. I need to make a decision of whether to lay balsa and epoxy it down and glass over, or to cut the coaming down and fair smooth. It looks like I may need to get an angle grinder.
n8kraft is offline
post #15 of 50 Old 05-02-2013
Asleep at the wheel
jimgo's Avatar
You know, without pics this really isn't that great of a thread.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #16 of 50 Old 05-02-2013
x2!
OldCreek is offline
post #17 of 50 Old 05-03-2013 Thread Starter
Commodore
n8kraft's Avatar
OK, more pictures and a status update.
My dock neighbor, Jay from JAYGAR is on the right helping scrape off the sticky tar stuff, while I'm on the left with my head down out of the frame removing bedding compound. So far I've used three different methods to remove the sticky stuff and the easiest one was using a paint or varnish scraper. The other less successful methods were using a Scotchbright green scrubbing pad with acetone and using a paint removal wheel.
This is a repost of a picture of the cockpit taken while standing on my dockbox showing how white and nice the cockpit looks after scraping the sticky teak bedding compound off and cleaning the area with acetone.
Here is my next problem. After removing the teak there's a half inch lip or coaming in the cockpit that I need to deal with. My first instinct is to cut it off with my Fein multimaster or a sawzall and then smooth it and fair with epoxy fairing compound, but before I make the fist cut I want to see if anyone out there in sailnet land has experience with this.
jimgo likes this.
n8kraft is offline
post #18 of 50 Old 05-03-2013
How about keeping the lip and using it to help retain some cushions? Perhaps, you can file some drainage slots in. Or, keep some strategically placed lips to do the same and grind off the rest...
OldCreek is offline
post #19 of 50 Old 05-03-2013
Asleep at the wheel
jimgo's Avatar
Yeah, I was wondering why you'd get rid of that lip, too. I like the idea of using it to hold the cushions in place.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #20 of 50 Old 05-03-2013
One of None
deniseO30's Avatar
You can scupper the lip. (notch it) so water drains and you will have a lip for cushions too!
My last project!
deniseO30 is offline
Tags
deck , nonskid , removal , replacement , teak
Maintain character of teak decks with nonskid n8kraft Gear & Maintenance 13 05-03-2013 02:39 AM
Replacement glued teak deck jamesjle Gear & Maintenance 3 10-06-2011 12:45 PM
Nonskid replacement Palustris Gear & Maintenance 1 04-12-2009 04:00 AM
Teak Deck replacement s1j1m10 Gear & Maintenance 8 09-16-2008 06:31 PM
Teak Deck Replacement - Flexiteek rbaker6966 Gear & Maintenance 8 04-17-2008 12:53 AM
