Teak Deck Replacement with Nonskid - Page 3 - SailNet Community
 11Likes
post #21 of 50 Old 05-03-2013 Thread Starter
Commodore
n8kraft's Avatar
Re: Teak Deck Replacement with Nonskid
We already have some cushions and they don't reach all the way out to the edge. After sitting in the cockpit for a few minutes that lip starts to cut off circulation to my feet so the lip's coming off. Now I have to figure out if it's easier to use the Fein Multimaster or a grinder.
Blog post about the beginning of the project At Aboard Astraea
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #22 of 50 Old 05-05-2013
1982 Skye 51
obelisk's Avatar
I did this same project in 2008 on my Skye 51, replacing my teak with Treadmaster--best money I have put into the boat! In deciding between the colors, know that the sand color I used has made the boat worlds more comfortable in the summer as it has dropped the temperature below decks significantly. Good work tackling it yourself!
Does the lip you are looking to get rid of come right up to the vertical surface of the cockpit? It might be difficult to get a smooth rollover using epoxy and filler, LOTS of sanding at a minimum. I have never tried it but maybe you could use a router and rollover bit if you faired with something soft like West 410 filler but that would be prone to chipping with every day wear and tear.
"The notion of life implies a certain absoluteness of self-enjoyment." -Alfred North Whitehead
obelisk is offline
post #23 of 50 Old 05-09-2013 Thread Starter
Commodore
n8kraft's Avatar
Obelisk:
The lip does go right up to the edge of the cockpit. I painted that area about a year ago when I replaced the windows. I'm prepared to do a bit of touch up paint around there and see how nicely I can smooth the deck paint in to the side paint, but that's a discussion for a later post when I'm closer to it. I've decided to remove more hardware and the reset of the deck before going in to the lip removal and fairing phase.
Today I removed all the chainplate covers:
Please ignore the drips on the toerail in the background. My varnishing skills are way better than that, it's just how the boat came.
All the covers for the chain plates have been removed and labeled. It took about two hours to unscrew all the plates, then loosen the turnbuckle and lubricate the turnbuckle with lanolin, an antisieze compound.
The tools I used are shown in the pictures, a wrench, electric and manual screwdriver and some pliers.
So here's the project plan as it stands now:
1) Remove the rest of the teak deck mounted hardware
Problem areas are the anchor windlass and bow pulpit and stanchions. They're through bolted, big, heavy or cumbersome so I'll need help with removing them. It's possibly going to get dirty in the cabin when removing this hardware because of the big holes.
Goal Date: Friday, likely finish date Saturday morning
2) Remove teak decks: Same process as before with mallet and hammer
Goal Date: Sunday, I'll have weekend help
3) Remove screws and clean up deck with scrapers and acetone
Goal Date: May 13, 2013
4) Prep Holes
Goal Date: May 15, 2013
5) Fill holes
Goal Date: May 22, 2013
Boy it's going to take a while. Guess I'll need to buy some extra beer and brats and call in the reinforcements.
jimgo likes this.
n8kraft is offline
post #24 of 50 Old 05-10-2013
1982 Skye 51
obelisk's Avatar
these pics look all too familiar! good luck getting everything off. just a note about getting the black goo off that remains after the teak is removed--i used a sharp, broad chisel to scrape the majority of the gunk off then used MEK, which worked way better for me than acetone. of course, it causes cancer 3 times as fast, so wear gloves...
obelisk is offline
post #25 of 50 Old 05-10-2013
No more curry buffets
Ritchard's Avatar
Am I to understand from the pic above that your chainplate is held in place with what appears to be wood screws?
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #26 of 50 Old 05-12-2013 Thread Starter
Commodore
n8kraft's Avatar
Ritchard,
The chiainplate was not held in with wood screws, that's just the cover to keep water out of the chainplate. It's not load bearing at all.
n8kraft is offline
post #27 of 50 Old 05-12-2013 Thread Starter
Commodore
n8kraft's Avatar
I tried removing the deck fill for the water tanks, but it's seized up. While holding it with a wrench I started to crush the tube. I need to use some PB Blaster penetrating fluid to break the nut free. If that doesn't work I'm going to cut the fittings off and replace them.
Top view of the water deck fill
My wife and I removed the screws and nuts for the stanchion bases and the jib lead track.
Then she got down to pulling up the teak.
And I got to play on the dock with my 11 month old son.
Yesterday we got all the teak up off the port side deck to the front of the cabintop. All the screws are out, the deck was cleaned of the old sealant, holes drilled and countersunk. We didn't do the jiblead track and stanchion holes yet. That will have to wait until later today or tomorrow.
Today we're taking a break for Mother's Day and going up to the restaurant for brunch.
n8kraft is offline
post #28 of 50 Old 05-12-2013
Minnesail's Avatar
What a cute boy! Wish your wife happy Mothers Day.
Minnesail is online now
post #29 of 50 Old 05-12-2013
Courtney the Dancer
jrd22's Avatar
Wow, do those pics bring back memories (nightmares?). Good luck with the project, you'll be justifiably proud when finished, and you'll never have to worry about a wet, rotten core.
Our deck replacement ordeal:
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #30 of 50 Old 05-13-2013
Ritchard's Avatar
Originally Posted by n8kraft View Post
Ritchard,
Of course, how stupid of me. I just removed mine similarly to do some painting. Brain fahrt.
OMG what a huge job you're doing. This may not apply to your boat, but based on my experience over this last winter I have decided that bargain boats that just need a little TLC are often not a bargain at all.
Ritchard is offline
Tags
deck , nonskid , removal , replacement , teak
Maintain character of teak decks with nonskid n8kraft Gear & Maintenance 13 05-03-2013 02:39 AM
Replacement glued teak deck jamesjle Gear & Maintenance 3 10-06-2011 12:45 PM
Nonskid replacement Palustris Gear & Maintenance 1 04-12-2009 04:00 AM
Teak Deck replacement s1j1m10 Gear & Maintenance 8 09-16-2008 06:31 PM
Teak Deck Replacement - Flexiteek rbaker6966 Gear & Maintenance 8 04-17-2008 12:53 AM
