Teak Deck Replacement with Nonskid - Page 4 - SailNet Community
 11Likes
post #31 of 50 Old 06-20-2013 Thread Starter
Commodore
n8kraft's Avatar
Re: Teak Deck Replacement with Nonskid
The job continues. I had to go out of town for work, but I'm back on the boat now.
Next problem is the chainplates come through the deck and are built up about a half inch with some epoxy and fiberglass so it doesn't collect water flush from the deck.
I'm trying to figure out how to clean up the edges and make it look nice and then seal it up. Right now my plan is to fill and fair, prime and paint, then seal around the chainplate with 3M 4000. Any other ideas how to make this look like a quality job? I don't want to cut it flush to the deck because of the added likelyhood of water intrusion.
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #32 of 50 Old 06-20-2013
Asleep at the wheel
jimgo's Avatar
I think I'd consider cutting it flush, leaving an 1/8" gap around the whole thing, then worry about how to re-seal it. I'd probably go with either Butyl or the UV version of 4200. You want something that can handle a good bit of movement.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #33 of 50 Old 06-20-2013
mitiempo's Avatar
I would remove the turnbuckle and then build it up 1/2" with some G10 with a slot for the chainplate. Size the G10 to the size of the cover plate at the top and wider at the bottom. Epoxy it in place. Add sealant around the slot and compress it with the cover plate. This will prevent water from pooling at the chainplate base. Like the pics below.
Butyl would be my sealant choice.
Brian
mitiempo is offline
post #34 of 50 Old 06-21-2013 Thread Starter
Commodore
n8kraft's Avatar
mitiempo: I like it. I usually walk around the marina looking for the way things were done on other boats, but your pictures show the whole process. Why did you reccomend the G10 epoxy? I've been using Westsystem for everything else and have never worked with G10 before.
n8kraft is offline
post #35 of 50 Old 06-21-2013
G10 FR4 Sheets, Panels & Boards | Cross Nail Laminates
It's pre fabbed f/g 'panel'. Also available at McMaster-Carr, I think...
Faster is online now
post #36 of 50 Old 07-13-2013 Thread Starter
Commodore
n8kraft's Avatar
Well, the project continues. I've been really busy. Here's the big bad update on the decks. I'll start with a link to the youtube video walkaround:
All the teak is off and the toe rail is almost ready to varnish. I'm going to put 6 coats of Epiphanes varnish on the toe rail. Then I can mask off the bottom and sand it prior to sealing the seam around the toe rail with 3M 4000. I've got to figure out how much I need. I'm thinking I'll go through 4 tubes on the inside and 2 tubes on the outside of each rail, so that's 12 tubes, or a case.
After everything is smooth and I think I'm ready to prime I'll drill holes and test fit the deck hardware. I want all the hardware can go back in the same place it came from and I'm not guesstimating where it came from and things are lopsided on deck. At this point I'll purchase new bolts, washers and nuts to replace the old bronze or stainless hardware that's now too long.
Next I'll prime the deck with about a gallon of Pre-Kote, then paint around the edges of everything with white Interlux Brightsides to match the cabintop, then roll the Durabak.
Finally I'll reinstall all the hardware, get the rig tuned and go sailing! I've still got about a month's worth of work to do!
n8kraft is offline
post #37 of 50 Old 07-13-2013
JulieMor's Avatar
WOW! Now I understand the $70K price tag the owner of a 44 footer paid for new teak decks.
Impressive work! Looks like you'll be buying your dockmates a lot of beers.
I think I need to share this with the SO so those boats we've looked with teak decks won't be so tempting.
Great job n8!
JulieMor is offline
post #38 of 50 Old 07-13-2013
Old enough to know better
YouTube
video shows up as private?
miatapaul is offline
post #39 of 50 Old 07-13-2013
Jnoiur Mebemr
StormBay's Avatar
Also cant see the video..
I feel for you n8kraft, we just got done with essentially the same project.
part 1 S/V Moitessier...: Decked Out
part 2 S/V Moitessier...: Awl or Nothing...
It took forever and all I can say is that Im glad I don't have to do it ever again. It looks like you guys are making good progress so far and Im looking forward to seeing the finished product
Yu & Frank
StormBay is offline
post #40 of 50 Old 07-14-2013 Thread Starter
Commodore
n8kraft's Avatar
Does the video work now?
n8kraft is offline
Tags
deck , nonskid , removal , replacement , teak
Maintain character of teak decks with nonskid n8kraft Gear & Maintenance 13 05-03-2013 01:39 AM
Replacement glued teak deck jamesjle Gear & Maintenance 3 10-06-2011 11:45 AM
Nonskid replacement Palustris Gear & Maintenance 1 04-12-2009 03:00 AM
Teak Deck replacement s1j1m10 Gear & Maintenance 8 09-16-2008 05:31 PM
Teak Deck Replacement - Flexiteek rbaker6966 Gear & Maintenance 8 04-16-2008 11:53 PM
