Teak Deck Replacement with Nonskid - Page 5 - SailNet Community
 11Likes
post #41 of 50 Old 07-14-2013
Jnoiur Mebemr
StormBay's Avatar
Re: Teak Deck Replacement with Nonskid
Yup it works now.
Yu & Frank
StormBay is offline
post #42 of 50 Old 07-14-2013 Thread Starter
Commodore
n8kraft's Avatar
StormBay: I've been to your part 1 page before, but this was my first time seeing the second. Good info on Perfection vs AwlGrip. I have AwlGrip left over from a previous project on my mast, but not enough to do the whole deck :-/ I already have a lot of a gallon of Brightside that I used to paint the sides of the cabintop. Based on your experience w/ the paint peeling up I'll probably end up going with AwlGrip and make the project a bit more expensive, but more durable.
Thanks!
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #43 of 50 Old 07-14-2013
Jnoiur Mebemr
StormBay's Avatar
I dont think you will regret using AwlGrip if thats the route you end up taking. It really is a quality product, and with a little practice its not as hard to work with as its reputation would lead you to believe.
Yu & Frank
StormBay is offline
The Following User Says Thank You to StormBay For This Useful Post:
n8kraft (10-22-2013)
post #44 of 50 Old 09-27-2013 Thread Starter
Commodore
n8kraft's Avatar
Astraea deck update 26SEP13 - YouTube
Getting ready to clean and roll primer, paint and nonskid!
n8kraft is offline
post #45 of 50 Old 09-27-2013
Asleep at the wheel
jimgo's Avatar
Wow, you must be excited! She's coming along nicely. Can't wait to see the final result!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #46 of 50 Old 10-22-2013 Thread Starter
Commodore
n8kraft's Avatar
S/V Astraea with Durabak beige nonskid - YouTube
Astraea finally has a new look. After two coats of Interlux Prekote primer and two coats of Interlux Brightside paint. We did one coat each day. The primer covered the entire deck and the paint went down just around the deck edges. In between coats we sanded with 220 grit and cleaned up with Interlux 333 brushing liquid.
We rolled most of the area and only brushed in the areas behind hardware and corners. We didn't roll and tip because the results from just rolling were really good, there were very few bubbles. While working on the deck preparation and painting we wore clean socks to keep dirt off the decks.
The day after our last coat of paint we taped the area around the deck edges and hardware we didnít want nonskid to go. It took us about 8 man hours to tape the entire deck. We made all the edges the same width of a roll of blue 3M painters tape. The straight edges were easy to tape, just put the tape against the edge and roll the tape. Natalie used a compass to draw some easy curves, but it didnít work for everything. She got creative and used kitchen tongs holding a pencil for curves around the deck house and hatches where a compass didnít work. We over taped and traced the width of a roll of tape then cut away the excess using an exacto knife and peeled up the tape.
We sanded the deck with 100 grit sandpaper and cleaned up the deck twice with rags wetted with Industrial Maintenance Coating Thinner. The directions for the Durabak nonskid calls for Xylene, but Xylene isnít available in California. Industrial Maintenance Coating Thinner is OK to use in place of Xylene.
Finally we were ready roll the nonskid! I opened the first can and mixed it up with our electric drill and a paint mixer and poured it in to a paint pan. I did some test rolling on cardboard to get used to rolling the textured material before rolling on the boat. It took about an hour and a half to cover the decks. I took a break and then rolled the second coat.
That night after the Durabak dried for four hours we could walk on the nonskid and peel up the tape from the edges before it fully cured. The tape came up easily if the Durabak wasnít too thick. We cleaned up areas where the tape tore with an exact knife. We had some issues with the tape pulling up the white paint underneath where it hadnít dried completely because we applied the paint too thick. We will touch up those areas later when we finish priming and painting the cockpit locker covers.
Weíre so excited that this project is almost finished! Itís been a long six monthsÖnow on to re-mounting all the hardware.
jrd22, Faster, JimMcGee and 4 others like this.
n8kraft is offline
The Following User Says Thank You to n8kraft For This Useful Post:
chucklesR (10-22-2013)
post #47 of 50 Old 10-22-2013
chucklesR's Avatar
Wonderful project and accomplishment.
chucklesR is offline
The Following User Says Thank You to chucklesR For This Useful Post:
post #48 of 50 Old 10-22-2013
Asleep at the wheel
jimgo's Avatar
I love the look of the teak deck, and it's a shame to see it go. That being said, you've done her proud - she looks really great! She looks like a "cleaned up" and more modern boat.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
The Following User Says Thank You to jimgo For This Useful Post:
post #49 of 50 Old 10-22-2013 Thread Starter
Commodore
n8kraft's Avatar
If only I were rich then I could have put down new teak. Still have more hardware to bed and some metal to cut away from the bow pulpit to make it mate correctly. We're working inside the boat to purge and organize things we haven't touched in forever in anticipation of the next underway!
n8kraft is offline
post #50 of 50 Old 10-27-2013
Great job! I am hoping to use nonskid after I finish a re-core on my deck. It looks like it worked well!
Quinn99 is offline
Tags
deck , nonskid , removal , replacement , teak
Maintain character of teak decks with nonskid n8kraft Gear & Maintenance 13 05-03-2013 01:39 AM
Replacement glued teak deck jamesjle Gear & Maintenance 3 10-06-2011 11:45 AM
Nonskid replacement Palustris Gear & Maintenance 1 04-12-2009 03:00 AM
Teak Deck replacement s1j1m10 Gear & Maintenance 8 09-16-2008 05:31 PM
Teak Deck Replacement - Flexiteek rbaker6966 Gear & Maintenance 8 04-16-2008 11:53 PM
