2-Blade folding propeller - SailNet Community
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 04-26-2013
First String
ltgoshen is on a distinguished road
So what o d when under sail? Foward netural with the transmission??
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 04-26-2013
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Re: 2-Blade folding propeller
Shut down the engine, push the trans into reverse for a moment to ensure the slip stream closes the blades and then shift back to neutral.
  #3
Old 04-26-2013
First String
Thanks thats what I thought but wanted to be sure.
  #4
Old 04-26-2013
If you're going to be a true fanatic... mark the prop shaft inside the boat when the axis of the two blades is horizontal.. and make sure the shaft locks/stops in that position.
That way, when you slow down in really light air the lower blade can't 'fall open' and add to the drag.
  #5
Old 04-26-2013
tommays's Avatar
The geared flex-o-fold just closes even when I grab my mooring and don't try
The martec on my friends boat which is not geared does require setting the shaft
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #6
Old 04-26-2013
True.. my comments were wrt a non-geared folder (which I believe Itgoshen has).
  #7
Old 04-26-2013
Maine Sail's Avatar
With my Flex-O-Fold it continued to spin in neutral. I had to lock it in reverse to get the blades to close.
______
-Maine Sail / CS-36T
  #8
Old 04-26-2013
msmith10's Avatar
Junior member, rest old
msmith10 is on a distinguished road
Itgoshen,
Do you have a diesel or an Atomic 4?
If it's an A4 you have to lock it in forward since the A4 has no positive lock in reverse.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
  #9
Old 04-27-2013
First String
Yanmar 2GM 13 hp at 3400 rpm's
  #10
Old 04-27-2013
JimsCAL's Avatar
JimsCAL is on a distinguished road
That's a Martec.
You may post attachments
You may edit your posts
2 blade or 3 blade propeller ddilman Gear & Maintenance 18 10-11-2012 09:00 PM
props - fixed 3 blade vs folding / feathering 2 blade BarryL Gear & Maintenance 2 01-25-2010 08:47 PM
2 blade or 3 blade propeller ddilman General Discussion (sailing related) 3 02-12-2006 12:45 PM
2 blade or 3 blade propeller ddilman Boat Review and Purchase Forum 3 11-07-2004 07:27 AM
propeller - 2 or 3 blade ddilman Boat Review and Purchase Forum 0 10-31-2004 03:46 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
