What are these things? - Page 3 - SailNet Community
 4Likes
post #21 of 29 Old 05-05-2013
Mechsmith
Re: What are these things?
Identical to mine, which shoots through the hull for depth gauge transducer. The hole is in the hull liner only. 79 Seafarer 22
Seafarer 29 KCB
Mechsmith is offline
post #22 of 29 Old 05-07-2013 Thread Starter
Mechsmith, have you ever switched the transducer with a plug?
OleSwole is offline
post #23 of 29 Old 05-08-2013
Mechsmith
Mine does not go through the hull. It shoots through the fiberglass. The flange was simply glued to the hull and the transducer mounted into the flanged part with the threaded knurled cap. No through hull required. This is the same way it worked with my new depth sounder in another boat.
Seafarer 29 KCB
post #24 of 29 Old 05-08-2013
Interesting.. and certainly a possibility - and a good one at that. Come to think of it there's been no mention of any leakage, right??
Faster is online now
post #25 of 29 Old 05-13-2013 Thread Starter
I thank you for the reply, Mechsmith. I'm trying to process the idea that you're putting forward, but am unable to picture how the sensor or sensing apparatus would meet the water.
OleSwole is offline
post #26 of 29 Old 05-13-2013 Thread Starter
So the other day, I took a screwdriver and placed it crosswise through the stiff wire on top, and gently nudged it to create a clockwise pressure.
Today, I was thrilled to see it was dry as a bone.
SO...in case some poor sap finds himself in this position in the future, and happens to see this thread, it will make me feel good to know he was helped.
OleSwole is offline
post #27 of 29 Old 05-13-2013 Thread Starter
OleSwole is offline
post #28 of 29 Old 05-14-2013
blutoyz's Avatar
Good thing you didn't haul out, take it out, fill it back in, barrier coat, and bottom paint.
blutoyz is offline
post #29 of 29 Old 05-14-2013
Mechsmith
It does not have to touch the water. It only needs a seamless interface with it. This is provided by the "cup" being filled with water or mineral oil sufficient to fill the space between the inside of the hull and the face of the transducer. This is the way it was done in my 79 Seafarer. In my 72 I mounted the transducer in a wet spot in the bilge. Occasionally I have to throw a cup of water in the bilge to keep it working.
Seafarer 29 KCB
Cal 34 things to look for HDChopper Cal 8 11-04-2011 08:39 PM
Things gone right wescarroll Gear & Maintenance 8 08-09-2008 12:21 PM
Things the sea has taken Fearless General Discussion (sailing related) 88 03-01-2007 04:28 PM
First things First paulk Seamanship & Navigation 12 02-24-2002 01:38 PM
