Sole replacement ideas, - SailNet Community
post #1 of 7 Old 04-28-2013 Thread Starter
Some one on here yesterday, or the day before posted something about replaceing/filling under his cabin sole with concrete ???? Anyway, I can't find the post, I see the one by 'Squidd" about his sole replacement. Anyone know where it went? Thanks.
AirborneSF is offline
post #2 of 7 Old 04-28-2013
Superior Sailor
Squidd's Avatar
Re: Sole replacement ideas,
I don't know if I have the best method... but I'm pretty sure filling the bildge with concrete is not a good idea..
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is online now
post #3 of 7 Old 04-28-2013 Thread Starter
Right, My C&C 26 has 'pockets' under the 'teak and holly', and that other post got me thinking about it. I liked your idea about filling with 'chopped fiberglass', or some such stuff. But I do like the idea of the added weight down low. "Just saying", ha, ha. Thanks.
post #4 of 7 Old 04-28-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
something to keep in mind with filling those pockets.. and this may sound counterintuitive.. You will make the hull stiffer in those areas by filling them. This will affect how the hull flexes when underway and when in any kind of rough weather. You could very easily be strengthening an area that was not meant to be strengthened and in doing so, subjecting other areas to newer and higher levels of stress they were not designed to handle.
If you want to add weight down low and do not want to use those areas for storage. I would build something to fit into the space, not something that fills it
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #5 of 7 Old 04-29-2013
chucklesR's Avatar
Spray in or pour in floatation foam might seem to be good, but the bottom line is you'll never find the leak that sinks you if completely cover your hull.
chucklesR is offline
post #6 of 7 Old 04-29-2013 Thread Starter
Both very good points. Thanks.
post #7 of 7 Old 04-29-2013
radcat's Avatar
I know this to be true. My first boat was a 1960s something 16 foot power boat. The PO thought it would be a good idea to spray in foam, cover the stringers and try to glass in the deck. I never did figure out where the water came from, but I ended up drilling holes in the deck to pump it out.
Radcat
PS 37
Hull# 210
radcat is offline
Soft Sole Replacement Squidd Gear & Maintenance 33 05-19-2013 10:56 PM
Sole Replacement davidpm Gear & Maintenance 0 03-18-2012 09:55 AM
cabin sole replacement jimrafford General Discussion (sailing related) 1 06-29-2011 07:16 PM
Galley Sole Replacement Stillraining Gear & Maintenance 38 08-06-2010 07:44 PM
Replacement Teak and Holly Sole (C&C 37) thomsonjd Gear & Maintenance 2 11-29-2001 05:17 PM
