Keel is chipping - SailNet Community
post #1 of 6 Old 04-28-2013 Thread Starter
Keel is chipping
Hey everyone,
We have just moved back aboard our 38 DownEaster after a two year break. Turns out that the dude who was supposed to do the bottom did not do the very bottom of the keel... ever!
Anyway, as I was doing the bottom today I came across two spots that chipped off. They are about the size of silver dollars. Again, this is at the very bottom of the keel. They are about as thick as an average butter knife. Not the really thick, 7 coats of paint, kind of thick that I was expecting.
My question:
Is there a way to temporarily fix it while it is in the water? I can not pull her out until September.
If not, what kind of damage could it do?
Thanks
Atraitees is offline
post #2 of 6 Old 04-28-2013
TQA
Bombay Explorer 44
TQA's Avatar
Re: Keel is chipping
Most builders will add extra layers on the bottom of the keel.
I would not worry about it and fair it on the next haul with epoxy filler.
TQA is offline
post #3 of 6 Old 04-28-2013
Wish I never found SN!
SimonV's Avatar
Are you taking about anti foul build up or the actual fairing material from the build.?
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #4 of 6 Old 04-29-2013
pauloman's Avatar
wet dry 700 (tm) kevlar reinforced underwater epoxy.
about 18 months ago it was used to repair a rotting 100 year old wooden marine railway in 12 feet of water. Saved the boatyard and 7 jobs.
pauloman is offline
post #5 of 6 Old 04-29-2013
I don't discuss my member
Fstbttms's Avatar
How do you know this if you haven't seen the bottom for two years?
Fstbttms is online now
post #6 of 6 Old 04-30-2013 Thread Starter
I went back under to finish the job today. I could see a little better. Yes, it looks like extra build up on the keel. It didn't have paint on it, so... my best guess is that it wasn't done during the build but some time after. Either way, it needs tending to.
The 700 looks really awesome. I think I'm going to use it for a temp fix. If nothing else, I have many other things I could use it on.
Either way she's not going to sink from it. I have confidence in that now...
Thanks so much for your help.
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 10:43 PM
Bottom Paint Chipping flyingjib General Discussion (sailing related) 8 04-20-2012 11:06 AM
Removing old clear coat that is now chipping and... Petar Gear & Maintenance 3 04-26-2011 11:19 PM
paint chipping off mixing elbow rmeador Gear & Maintenance 12 10-19-2010 12:46 PM
Avoiding rock chipping Saylorman Gear & Maintenance 6 04-15-2006 09:20 PM
