Problems keeping prime in freshwater system - SailNet Community
post #1 of 3 Old 04-28-2013 Thread Starter
lajimo's Avatar
My pressurized freshwater system went out recently and I isolated the issue to the pump. Having replaced the pump I had problems getting prime until I fixed a loose seal on the strainer. After taking care of that, all was well - no prime problems, good pressure, acceptable flow. I left the boat for a weak (all dc power off) and when I returned no prime. After activating the power the prime comes back but then fades out completely after only 20 sec with a faucet on.
The system is a bit complicated. As far as I can tell tank water runs from the forward tank (under v berth) to a canister filter under the galley sink. It then routes back through the pressure pump, which winds up feeding two heads with showers, and the galley sink. I'm sure the new pump is okay. Thinking it must be the canister filter? Or maybe an unknown leak somewhere?
lajimo is offline
post #2 of 3 Old 04-28-2013
JimMcGee's Avatar
Re: Problems keeping prime in freshwater system
Sounds like a leak somewhere in the system. Is water finding its way into the bilge?
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #3 of 3 Old 04-28-2013 Thread Starter
lajimo's Avatar
No water in bilge as far as I can tell. (But its not the cleanest and its hard to tell). Have checked connections at outputs and all seem tight.
lajimo is offline
Freshwater system for sailboat Ulchute Cruising & Liveaboard Forum 9 11-23-2012 01:59 PM
Freshwater System Flush BGS Gear & Maintenance 3 08-12-2012 03:34 PM
Fuel system losing prime dhornsey Gear & Maintenance 9 07-07-2008 05:40 PM
