Back for more - portapotty vs. manual head - Page 2 - SailNet Community
post #11 of 14 Old 04-29-2013
Re: Back for more - portapotty vs. manual head
Re-route the waste line up to a vented loop and then downhill to the holding tank. Consider the Lavac head to use little flushing water, given the very small tank.
I only repeat, since this was buried in a note that appears before the question was asked again.
If it can be done, I prefer a holding tank as one must use nuclear chemicals in a porta-potty that are ultimately dumped into the environment.
Good luck.
Jeanneau 54DS
Minnewaska is offline
post #12 of 14 Old 04-29-2013
Why not sea trial your system with a few gallons of fresh water ? Maybe it'll work just fine as a liquid waste disposal system.
capttb is online now
post #13 of 14 Old 04-30-2013 Thread Starter
Thank you for the advice, everyone. It seems that the general consensus is that the setup leaves something to be desired.
We don't have many options as far as placement of the holding tank (or increasing its size), but I think the suggestion that we really try to deal with this in the fall is spot-on given that the relatively short sailing season is almost upon us.
I think we're going to take it out for now (keeping the parts), put in a portapotty, and reevaluate in the fall if necessary. The idea of removing an unused system is much more appealing than using it this season, perhaps dealing with various problems, and then having to remove it once it's been "broken in", so to speak. We could just leave the whole thing alone and rely on water bottles and a bucket in an emergency, but while I have no problem with a Lady J, a bucket may be pushing it.
Thanks again.
"Pegu Club"
1977 Bristol 29.9
cthoops is offline
post #14 of 14 Old 04-30-2013
tommays's Avatar
Sealand Traveler all in one
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
head manual Belgiansailor Gear & Maintenance 2 10-23-2015 12:50 PM
question regarding electric head vs manual our38 Gear & Maintenance 26 08-05-2013 09:36 PM
New Manual Head SVCarolena Gear & Maintenance 7 05-04-2010 01:56 PM
Need manual for Jabsco/PAR 59128 head dman535 Gear & Maintenance 0 05-05-2009 05:34 PM
Problem with pump for manual head voodooacrobat Gear & Maintenance 6 07-06-2006 05:24 PM
