Through-Hulls - SailNet Community
 6Likes
post #1 of 54 Old 04-28-2013 Thread Starter
Through-Hulls
Hello everyone,
I recently purchased my first keelboat, a Pearson 30, hull 225, and I've been having fun tracing out systems, exercising sea-cocks, replacing hoses, etc. I replaced the head suction hose with 3/4" heater hose from the auto shop. I found four seacocks, none of which have been moved in many years, I'm afraid. One raw water to head, one is raw water to sink, one is engine cooling water, and the fourth was the old head overboard which has been closed and sealed off in the hose.
I tried to exercise the three working ones, and was partially successful. The engine cooling water is a 1/4 turn ball valve and works fine. The head suction moved after some persuasion, but the sink water seacock handle broke off in the channel lock jaws. I then backed out the tapered plug and went to the local shop to get a replacement. The shop told me that a replacement plug was probably not available, and that I should just remove the entire seacock and replace it with a 1/4 turn ball valve. They said to be careful that the through hull does not turn - have an assistant hold it on the outside of the hull (two nubs on the ID - jam in a flat handle and hold it with an adjustable wrench?). They said the threads may be straight, not tapered, and the new valve would be tapered threads.
What do you guys recommend? Should I replace the through hull as well? Can I find a replacement tapered plug and save myself some hassle?
VentureCat15 is offline
post #2 of 54 Old 04-28-2013
Re: Through-Hulls
Replace them all, and replace the thruhulls at the same time. They are a very important safety device, and you need to make sure every thing operates as designed and all components fit together. Or eliminate the ones you won't be using and repair the hole in the hull. Replacing the fittings might be cheaper and easier.
jlc likes this.
wescarroll is offline
post #3 of 54 Old 04-29-2013
Re: Through-Hulls
Replace the whole lot. This is not something you want to fail underway. Some thru-hulls are designed to take a step wrench, on others you may need an internal pipe wrench that has a cam to keep it from turning.
jlc likes this.
Jeanneau 54DS
Minnewaska is offline
post #4 of 54 Old 04-29-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Through-Hulls
I totally agree. Nothing will ruin your day of sailing faster than sinking
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #5 of 54 Old 04-29-2013
outbound's Avatar
Re: Through-Hulls
As you are doing this may wish to give thought to creating a manifold ( or several) so multiple needs can be serviced by a single thru hull. Eliminating thru hulls decreases complexity, increases safety. Both good things. Some set up their boats to have the engine cooling on it's own, all salt water domestic on another. and heads separate. You have a blank slate. Use the opportunity to make your life better down the road.
Windswift likes this.
s/v Hippocampus
Outbound 46
outbound is offline
post #6 of 54 Old 04-29-2013
Re: Through-Hulls
This is NOT something to fool around with!
I just replaced 3 thru-hulls on my boat that had regular ball valves threaded on to them. I cut out a "donut" of 1/2" G10 for a backing plate, shaped it to conform to the hull curvature and epoxied it in place. The bronze seacocks are the GOOD quality Groco's, not the cheaper version that has the chrome plated brass ball. I feel much better now knowing this will always work. I was concerned b/c if something shifted and smacked into the old setup it could have snapped off the thru-hull. You may want to use MARELON; I considered it but the Groco bronze ones are pretty much bulletproof as long as you operate them regularly.
Here is a pic of what it looked like when I was done.
Check out MAINESAILS pics on his thread about thru-hulls.
CS 36M DIANTHUS
sailordave is offline
post #7 of 54 Old 04-29-2013
outbound's Avatar
Re: Through-Hulls
Dave you do good work. Beautiful installation. What are your rates? (GRIN). Agree with you about marelon. Know they are put in some very fancy boats but somehow feel safer with metal on metal.
s/v Hippocampus
Outbound 46
outbound is offline
post #8 of 54 Old 04-29-2013
jsaronson's Avatar
Re: Through-Hulls
"They said to be careful that the through hull does not turn - have an assistant hold it on the outside of the hull (two nubs on the ID - jam in a flat handle and hold it with an adjustable wrench?)" No, use a "step-wrench"
Nice work Dave!
jsaronson is offline
post #9 of 54 Old 04-29-2013
Fresh water refugee
katsailor's Avatar
Re: Through-Hulls
Nice work, don't you need to ground the bronze through hull fittings to protect against electrolysis? It's one of the reason I am considering the MARELON fittings when I replace mine.
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #10 of 54 Old 05-03-2013 Thread Starter
Re: Through-Hulls
Following everyone's advice here - I removed the old W-C tapered plug seacock and purchased a replacement Groco, and will be installing it this weekend with 5200. Thanks for the input everyone.
thru-hulls? minnow1193 Gear & Maintenance 3 02-11-2012 10:19 PM
Thru-hulls ctj1950 General Discussion (sailing related) 8 04-04-2011 12:39 PM
More than 3 hulls? Ever been done? TintedChrome General Discussion (sailing related) 19 10-09-2010 07:09 PM
2.5 hulls planzman Boat Review and Purchase Forum 4 07-18-2008 11:20 AM
Through hulls drynoc Gear & Maintenance 5 08-14-2006 01:47 PM
