Dislodging Edson pedestal bolts - Page 2 - SailNet Community
post #11 of 17 Old 04-30-2013
Wish I never found SN!
SimonV's Avatar
Re: Dislodging Edson pedestal bolts
I had to do mine a couple of years back. Mine where not bolts but countersunk flat head 1/4" machine screws 6" long as I have an extender ring for the compass and engine controls. Drill the heads of, start with a very small pilot hole then a 5/16 drill to take the heads off. Invest in a good sharp/new cobolt drill, go slow and use cutting grease, don't get the head hot as it will harden and you will need to do something else. When the heads are off lift off the bezel you will now have four 1/4' pins to get out, I found a small pipe wrench worked best. WARNING WARNING do not apply any form of heat to the bolts as the pedestal is cast aluminum and will disintegrate.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is online now
post #12 of 17 Old 04-30-2013 Thread Starter
I have the same set up, so in retrospect I realize the screws (not bolts) are longer than the 4 inches I originally indicated. I'm encouraged that your approach worked. Another poster recommended using an electric impact driver. I'd like to give that a shot for two reasons: a) it would be much quicker and simpler it worked; b) I'd now have a new impact driver in my tool collection! Since one of the screws came out with just (correction: a lot) of arm muscle, I'm hoping the other three are just being stubborn and a nudge from the impact driver would move them along. The risk, of course, is that the screws might break at some awkward point as dictated by Murphy's Law.
nestorph is offline
post #13 of 17 Old 04-30-2013
SimonV's Avatar
I tried the impact driver as well, the problem is the bolts are so long they twist, absorbing the force of the impact over their lengh. I had a mate push down on the screw driver with all his weight and I turned it with a wrench across the blade. I managed to twist it 180deg before the blade slipped.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
DELIVERY SKIPPER
post #14 of 17 Old 05-02-2013 Thread Starter
FWIW--I contacted Edson about getting replacement screws. They confirmed the "drill out the heads and grab the remaining shafts with a vise grip" approach. Replacement screws are only $27 for a set of four! I asked if they were gold plated but didn't get a laugh.
nestorph is offline
post #15 of 17 Old 05-02-2013 Thread Starter
I may have spoken too soon. When I went to the website, I saw that the screws Edson is selling are 3 1/2 Phillips heads. My screws are slotted flatheads. A call back to Edson resulted in the support tech admitting he knows nothing about that type of screw. So now I have to source them myself. Sigh.
nestorph is offline
post #16 of 17 Old 05-02-2013
Fresh water refugee
katsailor's Avatar
Try McMaster-Carr, I don't thnik the head crss vs straight really matters. They make it with an allen or torx also which may be much easier to extract down the road.
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #17 of 17 Old 05-02-2013
Learning the HARD way...
eherlihy's Avatar
I was about to suggest heat from a butane torch (my favorite boat tool) when I read the above. I believe if the heat is properly modulated it could help.
I used heat on the mounting plate for my mast mounted halyard winch, which is made of aluminum, to remove the stainless steel screws, which were threaded and frozen into the aluminum plate.
Initially I could not move these screws at all. I tried PB-Blaster, and a #3 phillips bit in my Milwaukee cordless drill.
I finally safely removed 4 of the 5 screws (number 5 was already buggered and snapped) using heat... #5 came out with the liberal use of a ball peen hammer.
eherlihy is online now
Edson wheel removal from pedestal ambianceack Gear & Maintenance 7 04-22-2013 03:37 PM
Edson pedestal brake question Joesaila General Discussion (sailing related) 10 04-17-2013 08:44 PM
Edson Pedestal Paint? T37Chef Gear & Maintenance 30 04-03-2013 05:08 PM
Removing engine controls from old Edson pedestal Flight Risk Gear & Maintenance 2 01-12-2013 01:54 AM
Edson Pedestal Instrument Mounts thisisus Gear & Maintenance 2 05-05-2009 04:53 PM
