How big of an inverter to run AC/Heater? - SailNet Community
 1Likes
post #1 of 15 Old 04-29-2013 Thread Starter
Weekend Sailor
I tried to run the heat whilst away from dock power without success. The A/C & Heat system uses a heat pump. The capacity is 16,000 BTU.
The system starts up and as the compressor kicks in, a Compressor Fault shows up on the control unit.
I have a 2500watt inverter and I get the same result on engine and on battery alone.
any idea about how much power is needed to run this thing?
Attached are images of some of the essential pieces.
Thanks in advance
/ed
edguy3 is offline
post #2 of 15 Old 04-29-2013 Thread Starter
Weekend Sailor
Re: How big of an inverter to run AC/Heater?
Here are the images:
Part in Bilge
Part #2
Part #3
Part #4
edguy3 is offline
post #3 of 15 Old 04-29-2013
sailvayu's Avatar
This is not a practical thing to do. Even if you have a large enough inverter (which you do not) it would kill your batteries in short order. If your system is wired up so that you can even turn on the AC from the inverter your system is wired wrong and you need to have it checked.
Capt. Wayne Canning, AMS
sailvayu is offline
post #4 of 15 Old 04-29-2013
NautiG's Avatar
It'll run better if you run a coffee maker and a microwave at the same time.
But seriously, you will not be able to run a heat pump off your batteries and an inverter. What motor do you have?
Honda 2000 or propane heat as a solution?
Scott
Gemini Catamaran Split Decision
NautiG is offline
post #5 of 15 Old 04-29-2013 Thread Starter
Weekend Sailor
Thanks for the quick replies.
It's a 50 hp yanmar.
edguy3 is offline
post #6 of 15 Old 04-29-2013
Even a Honda 2000 won't run a 16k BTU unit.
Agree with everyone else, trying to run that large a AC unit on batteries is not a good idea. Maybe a 5000 BTU unit with a large house bank of batteries would work.
Catalina 34
chuck53 is offline
post #7 of 15 Old 04-29-2013
ebs001's Avatar
I checked on another forum and the start amperage for a 16K A/C is around 55 amps at 120 volts. That's 6600 watts. The run amperage is 13 amps and if the inverter were 100% efficient, which it is not, that would be 130 amps at 12 volts.
ebs001 is offline
post #8 of 15 Old 04-29-2013 Thread Starter
Weekend Sailor
That's the technical info for which I was looking. I'd estimate that I have a 50-75 amp alternator/generator, but, even at that rate, the deficit will run the batteries down too quickly. Furthermore, it's not worth upgrading the inverter and associated wiring to support that initial power draw.
So, I'll give up on that idea. ( and also figure out why I was able to turn the heat on without shore power. )
Thanks for the input and discussion!
/ed
edguy3 is offline
post #9 of 15 Old 04-29-2013
One of None
deniseO30's Avatar
When the compressor runs in the heating cycle it draws way way less amps then when it's in cooling mode. If it's rated to run at, say 10 amps in cooling, in heating it would draw about 3-5
My last project!
deniseO30 is offline
post #10 of 15 Old 04-30-2013
JimsCAL's Avatar
Even if you were able to get the unit started, it would suck even a good sized house battery bank down in a short time. Only practical way is a properly sized generator.
JimsCAL is offline
Inverter SayGudday Electrical Systems 0 12-26-2012 10:56 PM
12v an Inverter or both? sailguy40 Electronics 4 06-01-2010 08:35 AM
Inverter gdaiy Gear & Maintenance 1 04-10-2008 08:17 PM
Inverter HELP please??? Delton Gear & Maintenance 6 07-21-2007 10:53 PM
Inverter southernman Gear & Maintenance 0 03-23-2003 02:52 PM
