Applying Epoxy in Blind Spot - Page 2 - SailNet Community
post #11 of 12 Old 04-30-2013 Thread Starter
Shack's Avatar
Re: Applying Epoxy in Blind Spot
Originally Posted by Barquito View Post
What does that mean?
I think he meant "cosmetic"?
"Not just a keel and a hull and a deck and sails..."
Shack is offline
post #12 of 12 Old 05-01-2013
pauloman's Avatar
first of all you need an epoxy that will bond to wet or damp surfaces. Most do not
also it is often impossible or almost impossible to fix an active leak from the inside.
splash zone a 788 - mentioned above - is like chewing gum. You need something thinner like wet dry 700 (which is often carried on boats sailing the world - and has saved a number of sinking boats, floating homes and cracked in ground swimming pools.
paul
pauloman is offline
Applying Cetol jackytdunaway Gear & Maintenance 3 06-30-2009 12:11 PM
Applying Epifane Mono-urethane paint. First Time pheffley Gear & Maintenance 7 10-19-2008 11:31 AM
Applying Barrier Coat Sixbrothers Gear & Maintenance 3 02-12-2008 09:23 PM
Applying Sea Dek... Prep stages Lancer28 Gear & Maintenance 1 09-29-2007 02:43 AM
rash decision: applying gelcoat tappers Gear & Maintenance 0 09-18-2002 02:27 PM
