Cruising Specialist Roller Furler??? - SailNet Community
 1Likes
  • 1 Post By Faster
post #1 of 7 Old 04-30-2013 Thread Starter
My survey indicates the furler is a "Cruising Specialist" brand. Has anyone heard of this unit? It has an extruded foil with internal wire halyard.
Thanks
Don
Invictus322 is offline
post #2 of 7 Old 04-30-2013
Re: Cruising Specialist Roller Furler???
CDI (Cruising Designs Inc) made furlers with internal halyards... what boat? Is it similar to this one?
http://www.sailcdi.com/sailpdf/FF7&9...ual%206_12.pdf
knothead likes this.
Faster is offline
post #3 of 7 Old 04-30-2013 Thread Starter
Thanks for the reply... that isn't it. My unit has an extruded metal foil.
post #4 of 7 Old 05-01-2013
CDI made many models. Many of the early ones had aluminum extrusions.
Post a pic for a definite ID.
knothead is offline
post #5 of 7 Old 05-02-2013 Thread Starter
On target! I went down the wrong path. It looks like a reefer rather than a furler. CDI has a couple of ancient models that look very similar. I will take some drum measurements to confirm. Still not grasping the difference between a reefer and a furler, though. Thanks for the assistance.
Don
post #6 of 7 Old 05-02-2013
.... Still not grasping the difference between a reefer and a furler, though. Thanks for the assistance.
Don
Today most 'furlers' are 'reefers'. Not all early 'furlers' were built to take the forces of a partially rolled up sail under pressure (or the 'rolled/furled' shape was so bad as to be unusable)... hence 'furlers' were meant to either fully deployed or fully rolled up. One claiming to be a 'reefer' was designed to deal with a partial roll, or furl. Modern roller furling units are usually able to be used 'reefed'.
Faster is offline
post #7 of 7 Old 05-02-2013
Group9's Avatar
Thanks
Don
I'm pretty sure a 1982 Cape Dory 25D I had, had a Cruising Specialist roller furler on it, when I bought it in 1984. I sold it in 1988 so my memory is not perfect. It worked great though.
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
Famet Roller Furler for Cruising LWinters Gear & Maintenance 11 09-29-2014 10:18 AM
Roller Furler Repair Gladrags1 Gear & Maintenance 12 08-05-2012 05:35 PM
Roller Furler ID? (w/Pic) Seafire327 Gear & Maintenance 6 05-21-2009 09:28 PM
Anyone know how to set up this roller furler somers12 General Discussion (sailing related) 2 05-26-2008 02:52 PM
Hoisting a roller furler jib L124C Gear & Maintenance 6 10-04-2007 06:57 PM
