Raymarine Speed/Sonar transducer - SailNet Community
post #1 of 2 Old 05-01-2013 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
I went to pull the transducer blank for the first time this season and had to use a pair of channel locks on the ring to get it out. Once out it seemed to have this greenish looking coating on it (similar to cooper corrosion) even though I thought the tube and transducer area all plastic. I inserted the transducer and after a daysail when I pulled it out I also ended up using the channel locks. Before inserting the blank I coated it with vaseline. Anyone ever have an issue like this?
brokesailor is offline
post #2 of 2 Old 05-01-2013
Re: Raymarine Speed/Sonar transducer
Is it mold? Did bottom paint get up inside?
Jeanneau 54DS
Minnewaska is offline
True Wind vs Crazy Speed Transducer bacampbe Electronics 16 10-15-2009 11:17 AM
DMI transducer to Raymarine ST60 adapter roline Electronics 2 07-12-2009 11:28 PM
Sonar transducer question... martsmth Gear & Maintenance 15 05-12-2008 11:20 AM
1983 Newport 27S-II Hull construction and Sonar Transducer Installation Stenn Newport 2 10-06-2007 04:38 PM
Horizon Wind Speed Transducer hamiam Gear & Maintenance 1 05-18-2006 12:26 PM
