how do i bond my mast - SailNet Community
post #1 of 6 Old 05-01-2013 Thread Starter
I have a Morgan 37 Oi. My mast is down and I was going to check the rigging and rebed it with zinc chromate paste which would isolate all the stays. Also found out the mast is not bonded. Spoke with a rigger who said bond to the mast step which I found is led so can't connect to that. Yard manager said bond to chain plate of one stay but if I rebed rigging with paste it would be isolated from the mast. Asked rigger about attaching to base of mast just above the step, he said no because next time the mast is removed the riggers wouldn't think to remove the bonding wire. What is the best way to do this? Was thinking of a large hose clamp at base of mast that I could slip the wire under then just loosen it to remove the wire but wouldn't that eventually deteriorate the mast base? What is the proper way and practical way to do this?
jasonr575 is offline
post #2 of 6 Old 05-01-2013
celenoglu's Avatar
Re: how do i bond my mast
Why do you want to bond the mast?
celenoglu is offline
post #3 of 6 Old 05-01-2013
sailvayu's Avatar
I would bond to the mast step. I am assuming you are bonding for lightning so this should be fine. I am not sure what you mean when you say the step is led? If you are saying it is lead that sounds odd as I do not think i have ever seen a lead mast step plate. I would guess it is aluminum. Here is an interesting link for lightning info: Lightning Protection on Sailboats
Capt. Wayne Canning, AMS
sailvayu is offline
post #4 of 6 Old 05-01-2013 Thread Starter
I am bonding for corrosion protection. The mast sits on the keel and the plate it sits into is led. From what I understand masts should be bonded to everything else just like through hulls etc to prevent them from wearing away. Am I wrong? I have had one of those clip on zincs attached to my stay when at dock and it is as good as new several years later. Therefore the mast is not bonded. Nobody else uses those zincs and has a bonded mast?
post #5 of 6 Old 05-01-2013
sailvayu's Avatar
OK I am sure your base plate is not lead but that does not matter. You do not need to bond your mast for galvanic corrosion it will not waste away if it is not bonded. Bonding is for underwater metals. Those clip on zincs are useless as you have found out and they only do anything if the are properly connected to the vessels bonding system and even then they are a waste of money. Some use them on rigging as a lightning ground but they are pretty much useless for that too. So to answer your question forget about it and go sailing.
sailvayu is offline
post #6 of 6 Old 05-01-2013
I'd just paint the bottom foot of the mast, and the mast base it mates to, with Zinc Chromate primer. Not paste, primer.
My mast and base had had the same treatment 15 years ago, and there was not a hint of corrosion when we pulled the mast a few months ago.
MarkSF is offline
Does DOW 795 ever cure, bond or dry? anerussis Gear & Maintenance 18 10-27-2012 03:31 AM
To bond or not to bond, that is the question! wildcard Gear & Maintenance 2 12-04-2006 11:33 AM
To bond or not to bond? maxim_rfeld Gear & Maintenance 5 01-27-2005 01:58 PM
