Old 05-01-2013
eisselhardt is on a distinguished road
In mast furling and clew
So, I have a 2010 Beneteau 43 with in-mast furling that I've had for two months now. We've sailed her quite often, but I notice that when the sail is fully unfurled, the clew is much higher (measured from the boom) than the tack--maybe a foot or more higher. At first, I thought the sail was installed at an angle in the mast, but on inspection it is clear that the luft is even with the mast all the way up.
Is that foot's diagonal run from tack to clew how it is supposed to be? I had an in-mast furling rig on my Bene 381, and the foot ran pretty much parallel with the boom.
Thanks!
Eric
  #2
Old 05-01-2013
Re: In mast furling and clew
Picture???
  #3
Old 05-01-2013
Alex W's Avatar
Alex W is on a distinguished road
It's a stupid question, but are your vang and mainsheet free (with the topping lift holding the boom up) when you unroll the main? The boom should be able to angle itself on the gooseneck to meet the shape of the sail.
1986 Pearson 28-2 "Elena"
frequent crew/prior owner on Catalina 25 "Lutra"
Shilshole Marina, Seattle, Puget Sound, WA, USA
  #4
Old 05-01-2013
night0wl's Avatar
night0wl is on a distinguished road
More outhaul tension!!!! My sail is flat/parallel with the boom too. When its not, its almost always because the outhaul has creeped loose through the outhaul spinlock cam-cleat
S/V Jendai
Beneteau 343
  #5
Old 05-02-2013
Thanks, folks. I don't think it is either of those possibilities as the outhaul tension is tight and the sail luft is flat against the mast. I will ease the vang, but moving the boom up a foot or so at its end just makes for a pretty picture, but doesn't seem to answer the problem.
I suspect that the sail is simply cut in such a way that from tack to clew rises when the luft is flat against the mast. Seems remarkably inefficient, and maybe it is time for a new sail set.....
  #6
Old 05-02-2013
Without pics it's hard to say, but it does sound like your foot is cut at an angle that sets your clew high.. usually done to clear dodgers/biminis/arches etc. But I have to say that you'll get better sail shape and drive if you let the boom 'rise' to the clew by further tightening your outhaul and easing the vang. A 2-3 year old boat shouldn't need new sails quite yet.. You might talk to a sailmaker about modifying the sail for a better fit.
  #7
Old 05-03-2013
azguy is on a distinguished road
I'd love to see a picture...
  #8
Old 05-03-2013
MSN2Travelers's Avatar
Badger Sailor
MSN2Travelers is on a distinguished road
Arrow Re: In mast furling and clew
Can't speak to your specific model but on my B352 the clew is higher than the tack when the sail is fully deployed.
The vang and the main sheet have to be eased slightly so the boom can float when the main is deployed and/or furled. My guess is the boom is up-angled between 3 & 5 degrees.
I set the topping lift to hold the boom about a half inch above the bimini and the boom rides a couple inches higher with the main all the way out.
Paul
`99 Beneteau Oceanis 352, #282 WiTCHCRAFT
Madison/Milwaukee, WI
Sailing Lake Michigan and the Great Lakes
  #9
Old 05-06-2013
Thanks guys!
I was out all day on the Chesapeake this past Saturday, and eased the vang and main to allow the boom to ride up to the sail clew. The angle looked to be about 5 degrees from tack to clew, but the performance was pretty good. (Sorry, having too much fun and totally forgot to take any rig pics!)
It does seem that by cutting the sail in that way (without a 90 degree angle at the tack), some sail area is lost and performance may suffer a bit. In any event, I've decided to stop worrying about it and just sail until I need new sails, then address the issue.
Thanks again for your thoughts!
Eric
  #10
Old 05-07-2013
Badger Sailor
Talking Re: In mast furling and clew
Next time you furl the main, look at the foot as it rolls up in the mast. If the Luff-Foot angle was 90 degrees, all of the "thicker" foot material would roll up on itself and potentially jam itself in the mast. By having the clew slightly higher than the tack (along with an eased vang & eased main sheet), the foot slowly climbs inside the mast and creates a more compact package inside the mast.
In-mast mains are for cruising. Serious racers should stick with a conventional main if you have an overwhelming need for every .1th of a kt of speed.
Paul
You may post attachments
You may edit your posts
In-mast furling davidpm Boat Review and Purchase Forum 36 01-01-2013 12:26 PM
Question about in-boom furling & in-mast furling KIVALO General Discussion (sailing related) 3 03-27-2012 09:33 PM
In mast furling rjcaudle Boat Review and Purchase Forum 1 07-03-2010 10:29 AM
In mast furling kootenay Boat Review and Purchase Forum 26 11-16-2009 10:43 PM
in the mast furling capnhook General Discussion (sailing related) 0 12-12-2000 02:06 PM
SEO by vBSEO 3.6.1
