THru-Hull Conversion Large to Small - SailNet Community
post #1 of 2 Old 05-02-2013 Thread Starter
DrB
So my 1979 Pearson 10M has flush mount cockpit scupper drains on the underside of the hull. They were mounted in with silicone and this year I decided to replace them. They weren't leaking, so the big question is, why screw with it? Well I did and opened up a can of worms.
The old thru-hulls have a angled flange (45 deg) with max diameter of 2.5 inches tapering a ^ 1.75 inches. The new thru-hull has a max diameter of ~3.5 inches, 45 deg angle and the inner diameter at ~ 2.0 inches and small step with a groove for sealant before it meets the threads. the old thru-hull has no step with groove before the threads.
Considering the following options:
  • Widen the hole in the hull to accomodate the wider flange
  • Machine the new thru-hull to match the dimensions of the old thru-hull. I have a machine shop looking into.
  • Forget the flush mount and fill the beveled gap with thickened epoxy and use a regular thru-hull.
I am leaning towards #3 as it minimizes work and cost and reduces the area of seal.
Thoughts.
Thanks. DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #2 of 2 Old 05-03-2013 Thread Starter
DrB
Anyone have an opinion on this?
I think by going with a non-flush thru-hull in those areas,I may lose 1/100th of knot, but save a ton of time and cost.
DrB is offline
Small main sail, large jib - questions matthewwhill Boat Review and Purchase Forum 58 12-28-2012 03:05 PM
Help for small hole in hull near Beaufort, NC synapse General Discussion (sailing related) 5 08-20-2012 01:06 PM
small large larger captdavi Introduce Yourself 0 06-06-2011 10:39 AM
propellers - large or small? anderbra Gear & Maintenance 3 08-14-2008 05:45 PM
