-   -   3/8 npt to 5/8 barb (http://www.sailnet.com/forums/gear-maintenance/99123-3-8-npt-5-8-barb.html)
thedude 05-03-2013 09:32 AM
3/8 npt to 5/8 barb
I'm having no luck finding this fitting in bronze or marelon. Groco, perko, forespar, apollo. None of these manufacturers make 3/8 stuff. Any ideas?
rugosa 05-03-2013 09:41 AM
Re: 3/8 npt to 5/8 barb
3/8 male or female, straight, 90, 45? photo would help
thedude 05-03-2013 09:55 AM
yes, that would help. i need a straight fitting, male 3/8 npt to 5/8 hose barb,
http://images.jamestowndistributors....0/00003895.jpg
Maine Sail 05-03-2013 10:03 AM
What will this be used for?
blt2ski 05-03-2013 10:05 AM
You may need to do a 3/8-1/2" npt m-f reducer, then a 1/2"npt-5/8"barb. I've had to do that type of thing to get what I want in pipe fittings thru the years doing outdoor sprinkler work. Sometimes the fitting you want, literally does not exist, you you adapt!
Marty
tommays 05-03-2013 11:20 AM
The standard one is 3/4 NPT X 5/8 in marelon or bronze
3/8 to 5/8 shows up in Google BUT it is brass or NON-MARINE PVC
thedude 05-03-2013 12:03 PM
the fittings are for my raw water pump.
Argyle38 05-03-2013 12:36 PM
You are going to want to match the material of the hose barb adapter to whatever the 3/8 npt is mating to. 3/8 is not a typical thread size for bronze hardware so that's why it's hard to find. If it's brass then you can use brass for the application and brass barbs of that size are sold here:
https://www.fisheriessupply.com/midl...machined-brass
Otherwise, you might try Grainger Industrial Supply - MRO Supplies, MRO Equipment, Tools & Solutions They have a good selection of all sorts of fittings.
tommays 05-03-2013 01:16 PM
Is this on and A4 water pump ?
thedude 05-03-2013 01:50 PM
it's on a jabsco 2620 series pump with a bronze body.
