Getting sanitation hose over fittings - Page 2 - SailNet Community
 8Likes
post #11 of 21 Old 05-03-2013
CaptainForce's Avatar
Re: Getting sanitation hose over fittings
I find an electic hair dryer to be much more convenient than working with hot water.
Take Care and Joy, Aythya Crew
CaptainForce is offline
post #12 of 21 Old 05-03-2013
MikeinLA's Avatar
I redid my waste system last year with that awful white sanitation hose. I found that hose lube and cursing worked best. I saved a 2' piece of the hose so if I ever run across the inventor I can beat him to death with it.
Mike
CS Cruiser likes this.
MikeinLA is offline
post #13 of 21 Old 05-03-2013
pdqaltair's Avatar
Consider Raritan Saniflex. So easy it's like cheating.
Raritan Engineering | Sanitation Hose
I did a review for PS and thus have 6 different hoses on my boat.
Will it last as long? Hard to say, but I've not heard of any permeation failures... have you?
I do know this; I will never buy any white hose again; though I can work it with hot water, why bother when there are better products? and use straight (not barbed) fittings of the correct size.
Sail Delmarva: The Easy Button
Seaduction likes this.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Writing full-time since 2014
pdqaltair is offline
post #14 of 21 Old 05-03-2013 Thread Starter
kjzerr's Avatar
Well put Mike!! Made me laugh out loud!
S/V "Spirit" - 1971 C&C 36R
kjzerr is offline
post #15 of 21 Old 05-04-2013
Maine Sail's Avatar
I use an insulated SS coffee mug. Water stays hot for multiple fittings. Course I try damn hard to talk customers into real sanitation hose not the PVC junk that odor permeates as fast as a auctioneer talks....
The problem with heat guns and hair driers on this hose is that it is very difficult to heat it evenly. The hose then stretches more in one area than another and can later crack..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #16 of 21 Old 05-04-2013
Fittings like this, right:
Seaduction is offline
post #17 of 21 Old 05-04-2013
I used a heat gun which worked great. Just be carefull to not overheat the hose.
waterwks4me is offline
post #18 of 21 Old 05-04-2013
dinosdad's Avatar
buy a tailpipe expander {harbor freight, napa, advanced}just dont go crazy with it just enough to open the diameter slightly, let it set in the pipe for a few minutes, release it put the hose on ,
don't waste time because the hose will return to its original diameter pretty quickly...
1994 Catalina 320
Noank ct
dinosdad is offline
post #19 of 21 Old 05-04-2013
snake charmer, cat herder
zeehag's Avatar
funny....hot water worked just fine n dandy in my formosa...was a lil blood and tears and a heat gun with the hose in my ericson..
formosa 41, cruising tropics
zeehag is offline
post #20 of 21 Old 05-05-2013
Trident 101 & 102 are the best. They are also MUCH easier to fit than any of he white plastic crap hose
chef2sail likes this.
xort is offline
Tags
fitting , holding , hose , sanitation , waste
Vinyl sanitation hose: How to get it over tight fittings brucemoody Gear & Maintenance 11 08-23-2012 10:50 AM
Quick-connect hose fittings for bilge hose? cghubbell Gear & Maintenance 1 06-03-2010 04:45 PM
Good Source For Hose Fittings? SEMIJim Gear & Maintenance 15 07-23-2008 04:09 PM
Propane hoses & Barb fittings plus hose clamps surftom Gear & Maintenance 5 07-21-2008 12:56 PM
Spa flex PVC hose for sanitation hose TrojanSailor Gear & Maintenance 6 07-22-2007 09:51 PM
