Getting sanitation hose over fittings - Page 3 - SailNet Community
 8Likes
post #21 of 21 Old 05-14-2013
Re: Getting sanitation hose over fittings
Seaduction is right. You need fittings made for the marine sanitation hose and if you're trying to use standard hardware store barb fittings, they won't fit. Don't know why that is, but all the hot water and dish soap in the world will only get your hands slippery and the hose cleaner. I did the same job and ended up sanding the barbs down with coarse sandpaper. I had some limited success that way, but with the correct fittings, the hose slips on pretty easily.
Not that expensive and worth the money.
VallelyJ is offline
Tags
fitting , holding , hose , sanitation , waste
Vinyl sanitation hose: How to get it over tight fittings brucemoody Gear & Maintenance 11 08-23-2012 10:50 AM
Quick-connect hose fittings for bilge hose? cghubbell Gear & Maintenance 1 06-03-2010 04:45 PM
Good Source For Hose Fittings? SEMIJim Gear & Maintenance 15 07-23-2008 04:09 PM
Propane hoses & Barb fittings plus hose clamps surftom Gear & Maintenance 5 07-21-2008 12:56 PM
Spa flex PVC hose for sanitation hose TrojanSailor Gear & Maintenance 6 07-22-2007 09:51 PM
