Getting sanitation hose over fittings - SailNet Community
 8Likes
post #1 of 21 Old 05-03-2013 Thread Starter
kjzerr's Avatar
Good day all:
I am installing a new holding tank and replacing the sanitation hoses. I am using Triton sanitation hose (supposedly one of the most flexible), and I find it next to impossible to get it to go over the barbed fittings. Both the 3/4" intake and 1-1/2" outflow are equally as difficult. Any suggestions on making this task easier? Is there a lubricant available which aids slipping on the hoses?
Thanks in advance!
Kermit
S/V "Spirit" - 1971 C&C 36R
kjzerr is offline
post #2 of 21 Old 05-03-2013
T37Chef's Avatar
Re: Getting sanitation hose over fittings
try liquid soap first then if needed, heat the hose with a heat gun being careful not to melt it
rugosa likes this.
Shawn
T37Chef is offline
post #3 of 21 Old 05-03-2013
Mermaid Hunter
SVAuspicious's Avatar
I soak the hose ends in the hottest water I can manage for several minutes to soften and expand the hose. Smear a very thin bit of light grease on the hose barb. Shove hard.
SVAuspicious is offline
post #4 of 21 Old 05-03-2013
Maine Sail's Avatar
Originally Posted by kjzerr View Post
Good day all:
Thanks in advance!
Kermit
If they are PVC they are not really a 1.5" or .75".... You should use the white nylon fittings.. That said the cheap, odor permeating white PVC "sanitation" hose barely fits over the white nylon fittings so a soak in a coffee mug of hot water will do...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 21 Old 05-03-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
not sure if this is a help.. but we use this stuff for pulling wire
IDEAL INDUSTRIES, INC. - Yellow 77® Wire Pulling Lubricant
Works well and gets sticky when it finally dries
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #6 of 21 Old 05-03-2013
Tim R.'s Avatar
Hot water does the trick. If you tighten your hose clamps down while the hose is still pliable, the hose will conform to the barb and be impossible to remove without heat or cutting.
I would not use this hose myself. The Trident double wall #101 or #102 is a better hose to work with and will last longer.
chef2sail and msmith10 like this.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #7 of 21 Old 05-03-2013
chef2sail's Avatar
Totally agree. The green stripe is the way to go.
rugosa likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #8 of 21 Old 05-03-2013 Thread Starter
kjzerr's Avatar
Thank you to all who responded. your suggestions have helped.
BTW, it is the Trident green stripe that I am using, not triton. My bad.
kjzerr is offline
post #9 of 21 Old 05-03-2013
Tim R.'s Avatar
Well then hot water will not help much. A little water soluble lube is the way to go. Maybe some dish detergent.
Tim R.
1997 Caliber 40LRC
Tim R. is offline
post #10 of 21 Old 05-03-2013
Using these fittings keeps cursing to a minimum.
http://www.jamestowndistributors.com...t.do?pid=14702
Seaduction is offline
Tags
fitting , holding , hose , sanitation , waste
Vinyl sanitation hose: How to get it over tight fittings brucemoody Gear & Maintenance 11 08-23-2012 09:50 AM
Quick-connect hose fittings for bilge hose? cghubbell Gear & Maintenance 1 06-03-2010 03:45 PM
Good Source For Hose Fittings? SEMIJim Gear & Maintenance 15 07-23-2008 03:09 PM
Propane hoses & Barb fittings plus hose clamps surftom Gear & Maintenance 5 07-21-2008 11:56 AM
Spa flex PVC hose for sanitation hose TrojanSailor Gear & Maintenance 6 07-22-2007 08:51 PM
