Icom 504 to HM 157 hardwire - SailNet Community
post #1 of 2 Old 05-05-2013 Thread Starter
rdw
I have an ICOM 504 VHF radio with a HM 157 remote microphone. The connector that connects the wire from the radio to the remote was damaged. I was just going to hard wire the two together but after cutting the two connectors off I found that the color coded wires do not match up. I contacted ICOM support. They basically said they do not recommend hardwiring.
Anyone have experience with hard wiring?
Anyone know what colors to put with each other?
Thanks,
RDW
rdw is offline
post #2 of 2 Old 05-05-2013
Re: Icom 504 to HM 157 hardwire
you will need a schematic of the microphone and its conector tin and to the radio.
You will need a schematic or the microphone, its conector, and the connector in the radio. Check your local ham operators, or a Ham radio forum someone there with an ICOM 504 should have the information you need.
desert rat is offline
Ham Frequencies on my Icom 802 velero Electronics 1 03-26-2010 12:06 PM
Icom M710 Sanctuary54 Gear & Maintenance 15 12-13-2007 10:46 PM
icom m72 jobrantley Gear & Maintenance 6 08-24-2007 11:08 AM
iCom Handheld VASailor10 Gear & Maintenance 8 08-22-2007 03:04 PM
ICOM 700... lastfreedom Gear & Maintenance 4 09-20-2002 06:14 PM
