Black / gray deck spots - how to fix / prevent? - Page 2 - SailNet Community
post #11 of 17 Old 05-06-2013
chucklesR's Avatar
Re: Black / gray deck spots - how to fix / prevent?
Part two of your question was how to make it stay away.
Fill the micro pores/holes with wax, buff etc.
The only other way is to sell the boat and take up extreme rocking chair sports.
chucklesR is offline
post #12 of 17 Old 05-06-2013
g0twind's Avatar
I had the same problem...only worse. It was all over my topsides.
Here is a shot of the cockpit. Almost all of the black on the transom was the mold.
I used diluted bleach and a Scotch Brite pad, followed by large amounts of water.
1974 Paceship PY23 "Barely Awake"
Hull # 001
g0twind is offline
post #13 of 17 Old 05-06-2013
Do we get an 'AFTER' picture??
Faster is offline
post #14 of 17 Old 05-06-2013
g0twind's Avatar
That would probably help....
Hull # 001
g0twind is offline
post #15 of 17 Old 05-06-2013
chucklesR's Avatar
FSR cleaner would make that white again, but then you'd need to compound and wax it.
post #16 of 17 Old 05-06-2013
Old as Dirt!
svHyLyte's Avatar
Originally Posted by Reefpoints View Post
I'll try the dollar store citrus cleaner first (thanks TropicCat), if that doesn't work I'll look for the stronger stuff that svHyLyte recommended.
We did not find that the Citrus cleaners worked very well and finally went with the more aggressive method mentioned. If the Citrus oil approach works for you, it is important to ensure that all of the residual oil is thoroughly removed as we discovered the stuff becomes medium for mold itself once its acidic content is depleted. Note that if you are in an area with a fair amount of air pollution, the finish surface on Gelcoat and/or wax will erode fairly quickly as moisture in the air combines with the sulfur in the air particulates to create acid (think acid rain). Frequent washing and wax application is the only defense.
In any case, Good luck...
svHyLyte is offline
post #17 of 17 Old 05-06-2013
g0twind's Avatar
I tried FSR and it was unable to remove the black spots. I will be compounding and waxing before launching again to protect all my hard work
Hull # 001
g0twind is offline
Tags
spots
Black spots on the wood RossC32 Gear & Maintenance 12 08-24-2012 04:50 PM
Micro-balloons to prevent hard spots. Freerider Gear & Maintenance 1 06-16-2011 11:04 PM
Orange spots on deck - sunscreen WinterRiver Gear & Maintenance 6 07-31-2008 07:54 PM
At sea. Volvo Ocean Race: Brasil 1 spots spinnaker problems on Black Pearl @ BYM Sailing News NewsReader News Feeds 0 04-12-2006 02:15 PM
Crazying and Soft Spots on Deck GarrettK Gear & Maintenance 4 08-23-2004 12:57 PM
