Butane camp stove in cabin - SailNet Community
 2Likes
post #1 of 27 Old 05-05-2013 Thread Starter
Barquito
Barquito's Avatar
I have a small galley, and want to keep it simple (and inexpensive). Would it be safe to cook on a butane camp stove in the cabin, if we store the butane canister outside on the rail? Needless to say, I will only be cooking at anchor. I am mostly concerned about the safety having the gas canister in the cabin.
Valiant 32
Barquito is offline
post #2 of 27 Old 05-06-2013
Senior Slacker
SlowButSteady's Avatar
Re: Butane camp stove in cabin
A non-pressurized alcohol stove would be much safer. A butane stove will be cheaper in the short run, but one mishap can more than wipe out that economy.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #3 of 27 Old 05-06-2013
Wish I never found SN!
SimonV's Avatar
I don't see a problem as long as you don't keep the open canisters inside. As soon as you finish cooking put it outside. oh and don't smoke or run with scissors.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #4 of 27 Old 05-06-2013
Senior Smart Aleck
jameswilson29's Avatar
I have the same concerns about my 2 propane stoves, one gimballed and one camp-style 2 burner. I have resolved those concerns by only using the stoves below decks with full ventilation and a breeze - front hatch and companionway open, or by moving the 2 burner camp-style stove to the cockpit for cooking. I store the propane cannisters in the open cockpit storage bins so there is no danger of leakage below decks.
jameswilson29 is offline
post #5 of 27 Old 05-06-2013
Chastened
Ajax_MD's Avatar
I think you're going about it sensibly, and will be ok.
Just store the cans outside (but don't let them get rusty) and try to have some ventilation while you're cooking.
You could install a CO detector if you're really worried, but I think it's overkill.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #6 of 27 Old 05-06-2013
I use two butane camping stoves side by side in my boat - both single burners and very cheap. The canisters are stored in a proper air tight compartment near the transom and vented overboard. I built separate compartments for each with a lid to give extra bench space when not using the stoves. They are gimballed with a lead weight under the support frame. I also made some stainless retaining pot rails that bolt to each stove top. The red cap from the butane canister is left on the bench top while using the stove to serve as a reminder that a canister is inside the cabin. If the stove is not in use the rule for us is that the canister goes outside into the storage compartment. We also ensure there is always good ventilation within the galley.
Barquito likes this.
zilla is offline
post #7 of 27 Old 05-06-2013
JimsCAL's Avatar
Here's a marine butane stove. Not sure what they did to get it ABYC approved. At least it shows that butane can be used in cabins. No bargain however.
Seaward Princess 1-Burner Built-In Butane Stove
wdwright1967 likes this.
JimsCAL is offline
post #8 of 27 Old 05-06-2013 Thread Starter
Barquito
Barquito's Avatar
Zilla - Do you have any pictures of your setup?
I also have a bilge fan I could run after cooking. Seems like an evil science experiment cooking with heavier than air gas almost on top of a gasoline engine (A4).
Valiant 32
Barquito is offline
post #9 of 27 Old 05-06-2013
When I was hunting for boat insurance I had to provide picture proof that the cabin did NOT contain any stove. (Whatever was built in by the manufacturer was removed by PO's.
i_amcdn is offline
post #10 of 27 Old 05-06-2013
Barquito-
The butane burners are arguably reasonably safe. The cans are sealed metal that is only pierced by the stove when you insert them, so in theory they are quite leak resistant until used. (Although I've seen sealed R12 cans like that leak after 20+ years "through" the metal seal.)
After you've inserted the can in the stove, in theory you'd need to store the entire stove outside since the can has been pierced and you are relying on the seal. I don't underestimate the danger of gasses, but would mention I know a number of boats that use and store those same stoves, with gas in them, for years with no problem. I'd suggest a larger Tupperware container to store the whole thing, since that would tend to keep gas in and keep moisture out as well.
The invisible flame from alcohol seems to set more boats on fire (and boaters) than anything else in a galley. And takes forever to cook, too.
Take a look at the stove, and the seal, and for $25, hey, if you change your mind and take it home...worse things happen.
hellosailor is offline
Big Stove vs. Camp Stove tjgault Provisioning 14 02-06-2013 02:52 AM
Single burner Butane stove algee Gear & Maintenance 6 08-07-2012 06:44 PM
Butane stove dvuyxx Gear & Maintenance 10 05-01-2012 06:19 AM
Cheap Butane stove fuel cans!!! MacGyverRI Provisioning 14 04-14-2011 08:49 AM
Camp stove, where to use? leland515 Cruising & Liveaboard Forum 56 03-03-2010 10:38 AM
