Wire reinforced clear hose - SailNet Community
post #1 of 11 Old 05-06-2013 Thread Starter
It's been years since I've ordered this and can't find it anywhere. I'm going to do a project this weekend to install a flow meter (I know, high failure rate) and want to replace the clear raw water intake hose on the main engine, which is wire reinforced to prevent collapse. I prefer clear so that I can physically see the flow.
Anyone seen this anywhere? I tried Jamestown D, WM and Def.
Jeanneau 54DS
Minnewaska is offline
post #2 of 11 Old 05-06-2013
lajimo's Avatar
It's listed under Sanitation hose
lajimo is offline
post #3 of 11 Old 05-06-2013 Thread Starter
Re: Wire reinforced clear hose
Clear?
Jeanneau 54DS
post #4 of 11 Old 05-06-2013
tommays's Avatar
Kuri Tec
POLYSPRING® Series K7160 Reinforced PVC Vacuum & Transfer Hose On Kuriyama of America, Inc.
We use a clear PVC with and SS wire
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 11 Old 05-06-2013
pdqaltair's Avatar
a. Unless there is aeration (bubles) you won't see flow.
b. A flow switch would be a better choise than a flow meter. The switch could then rigger an alarm (you may not want to kill the engine, just in case you are in a tight spot). There are meters that could be durable in this application, but $$$$. Same reason knot meters are a pain. Better be ceartain it's accesible.
c. Clear (vinyl) hose is not going to hold up as well. It also won't stay clear long.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #6 of 11 Old 05-06-2013 Thread Starter
The clear vinyl we have now has held up for 8 years and, while slightly opaque now, you can still see flow. Agreed, you are more likely to see the tiny bubbles. However, if she isn't pumping at all, you can see the water sitting level below the strainer or pump and not have to wait for exhaust water. You can also tell if the thru hull is blocked, as the water will rise and fall with the thru hull open due to boat motion.
Jeanneau 54DS
post #7 of 11 Old 05-06-2013 Thread Starter
Originally Posted by tommays View Post
Thanks. Just to be certain, you use this for raw water intake to the seawater pump?
I might have to look for it in shorter lengths.
Jeanneau 54DS
post #8 of 11 Old 05-06-2013 Thread Starter
For what it's worth, I got one of these:
Aqualarm Save Your Engine Kit
I also have to replace the seawater strainer, as it has a leak and a new gasket didn't do the trick. Big air bubbles and failed to prime this past weekend. Had to sail into and anchorage to repair. Loaded it with water resistant winch grease to seal it.
Jeanneau 54DS
post #9 of 11 Old 05-06-2013
How wide a hose are you looking for? Up to an inch or so, I've seen clear hose that is fiber reinforced instead of wire. That's sold as "hot water" hose. I'd expect it to be just as strong. The wire is designed more to keep a hose from collapsing when it is under suction, IIRC.
hellosailor is offline
post #10 of 11 Old 05-06-2013
tommays's Avatar
I use the crazy black stuff that says marine UL overkill or not
Its not marine UL below the waterline rated BUT I don't believe any clear hose is
BUT it holds up on filling machines through mucho amounts of material and even more mucho amounts of hot water and sanitation cycles
Tommays
Northport NY
tommays is offline
JB Weld---reinforced fiberglas killarney_sailor Diesel 7 11-16-2011 09:25 AM
Sailboat races on Clear Lake offer landlubbers a waterfront view - Ultimate Clear Lak NewsReader News Feeds 0 08-16-2011 06:00 PM
Quick-connect hose fittings for bilge hose? cghubbell Gear & Maintenance 1 06-03-2010 03:45 PM
Reinforced Bilge? eherlihy Boat Review and Purchase Forum 13 05-03-2008 10:23 PM
Caution using wire reinforced water hose NauticalFishwife Gear & Maintenance 3 04-09-2008 09:21 PM
