Mismatched Standing Rigging Components - SailNet Community
post #1 of 3 Old 05-06-2013 Thread Starter
1968 Hinterhoeller HR28
The boat is new to me but I'm only second owner and original owner has sailed the boat for years as-is with no problems. Rig has double-lowers, single uppers with a single spreader.
The mast is down and I'm inspecting standing rigging components. Both uppers are 3/16 wire with an upper swaged eye fitting sized for a 3/8 clevis pin. But their tangs near the masthead are drilled for (an undersized) 5/16 clevis pin. So this boat has sailed for years with a 5/16 clevis holding a 3/8 eye. There is no visible deformation of the eye.
I am thinking of drilling out the tangs. I have read the guideline is that there should be as much tang metal surrounding the hole as the hole's diameter... and if I drill out the tangs I'll still be within that guideline.
Any thoughts on what I should do?
hriehl1 is offline
post #2 of 3 Old 05-06-2013
billyruffn's Avatar
Re: Mismatched Standing Rigging Components
Find a professional rigger and let them let you sort it out. Having the mast come down could spoil your day.**
**Not likely to happen after all these years, but......
billyruffn is offline
post #3 of 3 Old 05-07-2013
tommays's Avatar
I had pretty much the same deal on my 1970 Cal 29 and when I had rigging only copy the old parts they were able to put the correct fitting on all the standing rigging ends so the correct clevis pin could be used
I did have to make some minor mods to the mast tags as the new forks were a bit different but nothing that affected strength
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
standing rigging GoodOldBoater North American Yachts 10 04-18-2012 02:21 PM
Standing rigging- Doing it myself irwin325cc Gear & Maintenance 22 06-30-2011 07:32 PM
Standing rigging solman55 Gear & Maintenance 11 02-04-2011 10:47 AM
standing rigging ccriders Gear & Maintenance 9 10-12-2006 12:36 PM
Standing Rigging docsabre Gear & Maintenance 2 05-18-2002 04:48 AM
