Is this gelcoat/fiberglass recoverable? - SailNet Community
post #1 of 9 Old 05-07-2013 Thread Starter
First of all, as a new member I should say this forum is a wonderful resource.
I am looking into used Hobie cats, and found this one at a discount but with some considerable dirt and discoloration. I'm curious if fiberglass/gelcoat like this can be recovered, and how much work/money would the task involve.
Thanks!
can't post an image so I'll have to just do the link:
funjable.com/gelct.jpg
Cadyfatcat is offline
post #2 of 9 Old 05-07-2013
overbored's Avatar
Re: Is this gelcoat/fiberglass recoverable?
looks a little far gone. once it is pitted it is not going to polish up. whats at a discount, I have seen several Hobie 16 that are going for free. the Hobie's are everywhere and if you look you will find one that is worth saving. good complete Hobie will sell for around $1000. even the latter ones like the Hobie 18 are only $1500 to $3000. it's not just the hull that needs to be good condition, the Trampoline and the sails need to be in good shape or it is not a good deal even at free. if you have to buy a few parts to fix it up you will exceed the worth of the boat. the Hobie 18, Prindle 16 or 18 are much better sailing boats then the old Hobie 16.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #3 of 9 Old 05-07-2013
overbored's Avatar
here an example of one that looks a bit better then the discounted one. I do not know any thing about this boat but at $600, it looks like a good boat. Catamaran 16 foot sailboat
post #4 of 9 Old 05-07-2013 Thread Starter
Thanks overbored,
Ah wish I was in CA
When I say at a discount I mean $200, supposedly the rest is on good enough shape. Have yet to see the boat but assuming the hulls, sails and hardware are in decent shape, around me this seems like a pretty sweet deal.
So I understand pitting won't polish up, but is there any way to refinish it? Also, assuming none is below the waterline, might it clean up a bit to look more presentable, and I could just live with it?
post #5 of 9 Old 05-07-2013 Thread Starter
Also thanks for suggesting the Prindle, this also seems like a viable option now
post #6 of 9 Old 05-07-2013
overbored's Avatar
At $200 and if it is all there and usable. clean it up with soft scrub and go sailing. if it turns out to be the boat for you, then it might be worth a coat of paint. the deck gets the most sun and wear but also look at the bottom of the keel they can get worn thin to the point of leaking from dragging through the sand. check out Cat sailor for a lot of info and boats for sale Catsailor.com Classified Ads
post #7 of 9 Old 05-07-2013
One of None
deniseO30's Avatar
Looks more like mold and mildew. that the only pic? If it's nearly free I'd take it! if the bottoms are gone thin. epoxy cloth and fill the weave. maybe reinforce the inside bottom too. Fill, fair, and finish.....
My last project!
deniseO30 is offline
post #8 of 9 Old 05-07-2013 Thread Starter
funjable.com/catgt2.jpg
funjable.com/catgt3.jpg
post #9 of 9 Old 05-07-2013
One of None
deniseO30's Avatar
Take her home, clean her up, give her a name, show her some love...
My last project!
Gelcoat Mildew-I'm so sick of gelcoat mildew bwindrope Gear & Maintenance 45 11-15-2015 04:28 PM
Worn through to gelcoat? i_amcdn Gear & Maintenance 0 08-09-2012 09:43 PM
Fiberglass/Gelcoat Damage? mkrautha Sailboat Design and Construction 1 07-04-2008 10:47 PM
gelcoat or not to gelcoat? marcusn Gear & Maintenance 2 05-30-2008 02:44 AM
Abrasives to clean gelcoat and fiberglass labatt Gear & Maintenance 10 05-11-2007 12:17 PM
