Mast sheave box question - SailNet Community
post #1 of 8 Old 05-08-2013 Thread Starter
JoeLena's Avatar
On my small O'day Rhodes 19 the halyards run through the mast and exit the lower sheave box. When I received the boat the box was not attached to the mast, although there are small holes in both the mast and sheave box. What is the correct way to attach the sheave box to the mast?
JoeLena is offline
post #2 of 8 Old 05-08-2013
Re: Mast sheave box question
Joe, are there flanges on the fitting? I think that you may have it inside out in your photo. Normally, the sheaves will be inside the mast and the flanges outside and it's either screwed or riveted through the flanges and to the mast.
knothead is offline
post #3 of 8 Old 05-08-2013 Thread Starter
JoeLena's Avatar
It should be in there correctly. There are no flanges. The existing holes line up like I have it and the 'open' side has to point out for the halyards to go through.
Perhaps there were originally rivets there and the PO drilled them out? Just really small.
JoeLena is offline
post #4 of 8 Old 05-08-2013
Joe, I'm seeing the holes in the mast, but what holes on the sheave box are they lining up with if not holes in flanges?
knothead is offline
post #5 of 8 Old 05-08-2013 Thread Starter
JoeLena's Avatar
Sorry, I wasn't clear. The holes line up in the photo, I'm just not sure what fasteners to use. Looks like rivets would be it.
JoeLena is offline
post #6 of 8 Old 05-08-2013
I'd try pop rivets because they'd be so easy to install.
Hudsonian is offline
post #7 of 8 Old 05-08-2013 Thread Starter
JoeLena's Avatar
Sounds like a plan.
JoeLena is offline
post #8 of 8 Old 05-08-2013
I don't discuss my member
zz4gta's Avatar
where does your forestay attach to?
Merit 25 # 764 "Audrey"
zz4gta is offline
need help - squeaky sheave!! aelkin General Discussion (sailing related) 2 04-28-2013 08:37 PM
CAL 35 MK II: Sheave Replacement chrisd4700 Cal 3 02-06-2013 11:43 AM
7/16 inch masthead sheave? Tree Gear & Maintenance 1 03-29-2012 03:52 AM
Mysterious Sheave on the Mast. ClutchCargo Gear & Maintenance 1 03-01-2011 07:21 PM
It's a Sheave, not a Pulley sailaway21 Gear & Maintenance 35 12-13-2007 12:52 PM
