C&C 35 smile - SailNet Community
 1Likes
  • 1 Post By hellosailor
post #1 of 6 Old 05-08-2013 Thread Starter
hillenme's Avatar
C&C 35 smile
My hope was I had avoid this problem, but as soon as the fresh bottom paint was on last week i returned on Sunday to see a weep, about 3 inches in length on the port side of the leading edge of the keel, about 20 something inches down. I noticed leaving the yard Sunday and can't get back before they launch it on Saturday.
How concerned should i be by this? Can I assume it is still very small based on the length of crack in the paint, or do I have to get in there to know for sure? The boats in lake Michigan, so it will be hauled again in 5 months. How much worse will it get in that time?
hillenme is offline
post #2 of 6 Old 05-08-2013
ASA and PSIA Instructor
Re: C&C 35 smile
What model 35? What was status when it came OUT of water? My opinion would be, not a concern.
sailingfool is offline
post #3 of 6 Old 05-08-2013 Thread Starter
hillenme's Avatar
Re: C&C 35 smile
1984 MKIII. I just purcahsed the boat in October - I noticed nothing all year until the new bottom went on, and then I saw the weep.
hillenme is offline
post #4 of 6 Old 05-08-2013
jsaronson's Avatar
Re: C&C 35 smile
The smile is common. The keelbolts may need to be tightened. Specs can be found at cncphotoalbum.com. When you have time the joint should be cleaned and glassed over.
Joel
35/3
Annapolis
jsaronson is offline
post #5 of 6 Old 05-08-2013 Thread Starter
hillenme's Avatar
Re: C&C 35 smile
Thanks guys!
hillenme is offline
post #6 of 6 Old 05-08-2013
Re: C&C 35 smile
I think they were intended to be caulked and sealed, not glassed over. Glass won't have any flex and keels often will move around ever so slightly, requiring some flex on that joint. C&C being famous for a slight motion there.
bljones likes this.
hellosailor is offline
Not docking 101, SMILE! deniseO30 General Discussion (sailing related) 20 07-26-2011 04:52 PM
C&C Smile CliffR Gear & Maintenance 9 08-01-2008 04:54 PM
Catalina smile justified Gear & Maintenance 3 06-16-2008 07:11 PM
Big smile for our first little cruise aflanigan Cruising & Liveaboard Forum 3 12-28-2004 04:36 AM
