Thru Hull - SailNet Community
 3Likes
post #1 of 12 Old 05-08-2013 Thread Starter
Thru Hull
Is it ok to coat the threads of a thru hull to the valve with the grey plumbers putty
weephee is offline
post #2 of 12 Old 05-08-2013
tommays's Avatar
Re: Thru Hull
Kind of depends on what your trying ?
Putting a regular NPT valve on the NPS through hull ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 12 Old 05-08-2013 Thread Starter
Re: Thru Hull
The thru hull and valve have been in the boat since it was built in the 70's. It started leaking a small amount last year so before I launch the boat this summer, I removed the thru hull, cleaned it up and now I was going to use 4200 on the thru hull flange and plumbers putty on the threads for the actual valve.
weephee is offline
post #4 of 12 Old 05-08-2013
SoOkay's Avatar
Re: Thru Hull
Are you replacing the valve or reinstalling the old one?
SoOkay is offline
post #5 of 12 Old 05-08-2013
DrB
Re: Thru Hull
I replaced two thru-hulls on my boat this year that were original to to the boat. What a PITA (Different story), but I epoxied a pre-drilled backing plate to the hull and let cure overnight. Cleaned up any excess cured epoxy followed with an thorough acetone down on all mating surfaces.
Then I gooped up the thru-hull (threads too), buttered the inside of the thru hole, the back side of the seacock flange, and the back plate with 3M 4200. Then I assembled everything, snugged tight, and removed the excess 3M 4200.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #6 of 12 Old 05-08-2013 Thread Starter
Re: Thru Hull
I'm putting the original back in and have cleaned it up.
weephee is offline
post #7 of 12 Old 05-08-2013
Morild's Avatar
Re: Thru Hull
Do not do that, replace it.
But I guess the cavalery will arrive shortly, so I'm gonna grab some pop-corn for this.
SoOkay likes this.
Morild is offline
post #8 of 12 Old 05-09-2013
Re: Thru Hull
I wouldn't use plumbers putty, as others have suggested use 3M 4200 or sikaflex on the threads. Plumbers putty is more for sealing under faucets, shower valves etc.. and I have never used it on threads with any success, I have always used a teflon tape or thread sealer on the threads.
If your thru hull and seacock are the tapered cone type you may have to due a little more than clean it to stop it from leaking. As a thought you may want to check out the maintenance kit at sparten marine which can be viewed here www.spartenmarine.com
Or as Morild suggests replace it to insure things are working properly.
ambianceack is offline
post #9 of 12 Old 05-09-2013
Maine Sail's Avatar
Re: Thru Hull
Pipe dope not plumbers putty. I like Hercules Real-Tuff or Megaloc but there are many good ones out there.
When you have a thread mis-match, as you do with a thru-hull and in-line ball valve, I would suggest using both pipe dope and teflon tape to ensure a good seal. NPS and NPT are not really intended to be threaded together and is technically against the ABYC standards....
This is the difference between NPS to NPT and NPT to NPT....
kellysails and rugosa like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #10 of 12 Old 05-09-2013
SoOkay's Avatar
Re: Thru Hull
I think it would be best to replace the valve at this point, not reuse the old one.
SoOkay is offline
Hull indent on P30, where uppers meet the hull hamburking P30 5 07-18-2013 08:18 AM
P35 Hull #29 Sailmachine Pearson 2 07-14-2010 02:29 AM
Hull ID vs. hull number bristol321 Bristol 8 03-17-2008 10:01 PM
Multi-Hull vs Mono-Hull Sailboats? terryjoe Boat Review and Purchase Forum 8 11-11-2007 11:45 AM
Do you paint over thru hull bronze nipples on hull saurav16 Gear & Maintenance 4 08-19-2007 07:15 PM
