Galley water pump stopped - SailNet Community
post #1 of 9 Old 05-08-2013 Thread Starter
rbrasi's Avatar
So, I went sailing yesterday and spent the better part of four hours heeled over. When I returned I tried to wash my hands in the galley sink and some water came out, then stopped. The pump was still laboring, but the water didn't flow. Someone here told me that the vent for my fresh water tank is blocked, but I can't even find it. Does that sound about right? There is definitely water in there, it just won't make it's way to the pump (which is below the sink at floor level).
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #2 of 9 Old 05-08-2013
GeorgeB's Avatar
Re: Galley water pump stopped
Rbrasi, I can’t give you any specifics for your particular boat but here are some thoughts. The vent lines for your water tanks should be connected to the top of each tank. You can test for a clogged vent line by unscrewing the fill cover and trying the pump again. If you get water flow, with this, then your vent is plugged and you need to trace it and unplug it. If that doesn’t isolate the problem then you may have an inline filter that is plugged. This filter is there to protect the pump and most likely is located “just upstream” of the pump. Your Cal is pretty old and there are probably more than one previous owner mod made to your boat. You may have to do some more trouble shooting. No matter what, a day on the boat (even maintenance days) are better than a day in the office.
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #3 of 9 Old 05-08-2013
If you were heeled over extensively then maybe the pump has simply lost suction. As George said without knowing the specifics of your system it's gong to be difficult to diagnose.
Faster is offline
post #4 of 9 Old 05-08-2013
My initial thoughts are that the pump needs primed.
Seaduction is offline
post #5 of 9 Old 05-08-2013
Senior Slacker
SlowButSteady's Avatar
You might have knock some scale/sediment loose while you were sailing and it's now clogging the intake. Or something shifted around and a hose is pinched.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #6 of 9 Old 05-08-2013
poopdeckpappy's Avatar
You may have to crack all faucets and let the pump cycle till air is out of the lines, then close each faucet, do the head first, close the cold first then hot, then go to the galley and do the same thing, cold first, then hot
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #7 of 9 Old 05-09-2013
lajimo's Avatar
Very similar thing happened to me recently and it turned out to be gunk in the bottom of the tank that shifted around and clogged up the tank outlet. Quick check is to disconnect your water line at the tank outlet -if it doesn't flow freely then that's your issue. I reversed my wet vac and blew into the line and it freed right up.
lajimo is offline
post #8 of 9 Old 05-09-2013
tommays's Avatar
There should be and intake screen as it tends to be easy to jam the check valves inside the pump with small chunks of stuff
The new ones have clear cover IF you can not find one I would thing something clogged the outlet check valve hence the laboring pump
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #9 of 9 Old 05-10-2013 Thread Starter
rbrasi's Avatar
I did like George B said and removed the fill cover and it ran, which leads me to believe it is the vent. I closed it, the water still flows but the pump makes a horrible noise. I had to leave the boat for a couple of weeks, so I can't address it for a while. I tried to follow the line to find a filter, but it disappears through bulkheads. I told this to an old salt and his response: 'well, it's a sailboat'
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
water heater stopped heating rmeador Gear & Maintenance 5 07-27-2011 10:39 AM
Water filter on a Gusher Galley 3 gpm foot pump? SanDiegoChip Gear & Maintenance 2 05-20-2009 02:28 PM
fresh water system stopped working after fill-up Bene505 Gear & Maintenance 26 08-11-2008 02:47 PM
Installing a galley hand pump witzgall Gear & Maintenance 10 07-17-2008 08:00 PM
Galley Water Pump maureena5 Gear & Maintenance 5 02-25-2006 09:33 AM
