rebuilding compass - Page 2 - SailNet Community
 4Likes
post #11 of 21 Old 07-29-2013 Thread Starter
Skipper Jer's Avatar
Re: rebuilding compass
OK as promised and I know you all have been waiting for the pictures.
These are not retouched or photoshop. Yes the difference between before and after is truly amazing.
jimgo likes this.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #12 of 21 Old 07-29-2013
Asleep at the wheel
jimgo's Avatar
Wow, you can't even see the glass/plastic in the last pic. Nice job!
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #13 of 21 Old 07-29-2013 Thread Starter
Thanks Jim. Good luck with your boat.
Nor'sea 27
post #14 of 21 Old 07-29-2013
davidpm's Avatar
Originally Posted by Captainmeme View Post
The rebuilding consist of new dome, bellows, fluid and LED bracket. A little Mcquires magic plastic goop on the bezel makes the bezel nice and black.
were did you get the domes, factory?
Also do you have a link for the stuff you used to fix the black plastic?
davidpm is offline
post #15 of 21 Old 07-29-2013 Thread Starter
I bought the parts from the factory, Ritchie & Sons. I'd have to look around for the cost. Wait I used paypal. About $160 for two rebuild kits which included the dome, bellows, o-rings, led holder, and two quarts of fluid. I don't have a link for the magic plastic goop.
A guy at work has been rebuilding an old car in the warehouse. He had some which I tried. Hopefully its still there as I need to polish the second compass. If its there I'll post the info.
Nor'sea 27
post #16 of 21 Old 07-30-2013 Thread Starter
OK, the magic plastic goop is "Meguiar's PlastX" .
Here is a link to some place.
Meguiar's PlastX Clear Plastic Cleaner and Polish - 10 oz | Free Shipping Available - Detailed Image
Bet Autozone or some other car part store has it on the shelf.
davidpm likes this.
Nor'sea 27
The Following User Says Thank You to Skipper Jer For This Useful Post:
davidpm (07-31-2013)
post #17 of 21 Old 07-31-2013
davidpm's Avatar
Is this the stuff you used to clean and blacken the black parts too?
davidpm is offline
post #18 of 21 Old 08-01-2013
Daniel - Norsea 27
Rhapsody-NS27's Avatar
The compass on my boat has a foggy looking lens, and may need liquid. I've been looking at it thinking there must be a good way to clean it. I'll have to see what kind it is and see if parts are out there for it.
Nice job on your cleanup.
Skipper Jer likes this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #19 of 21 Old 08-01-2013 Thread Starter
Yes, I used that stuff to only clean and blacken the black parts. The dome was replaced. The old dome had cracks. I think the cracks are due to stress introduced when the dome was formed.
I did try to clean the old dome with the Meguiar's PlastX. After seveal minutes of rubbing and buffing I couldn't tell the difference from the polished spot and an unpolished spot. Makes me think there is some clouding internal to the plastic.
Nor'sea 27
post #20 of 21 Old 08-01-2013
the pointy end is the bow
erps's Avatar
I replaced a diaphram on a compass years ago. The compass manufacturer wanted me to send the compass in to have it done, saying I would never get enough fluid back in to prevent a bubble. They mentioned putting the fluid in the freezer for a DIY'er but I found an easier method.
Tape a string onto the diaphram. Pour the fluid in while pulling on the diaphram a bit. Fill the compass up. As you're putting the plug back in, have it facing up and release the diaphram a bit to so that fluid is spilling out of the plug while you're tightening it up. No bubbles on the first try.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
The Following User Says Thank You to erps For This Useful Post:
fryewe (08-01-2013)
Rebuilding a Yanmar YSM-12 using YSB head superiorvoyager Diesel 7 12-09-2012 06:09 PM
Rebuilding A Sea Strainer Maine Sail Gear & Maintenance 2 01-17-2009 05:44 PM
Rebuilding 22' Sailboat JamesSea Sailboat Design and Construction 19 07-11-2008 10:31 PM
rebuilding the refrigeration box badsanta Gear & Maintenance 1 04-27-2008 12:17 AM
Rebuilding seacocks aphil138 Gear & Maintenance 1 01-04-2004 01:32 PM
