Any tips for removing corroded bolts at rudder? - Page 2 - SailNet Community
post #11 of 12 Old 05-10-2013
Tundra Down
downeast450's Avatar
Re: Any tips for removing corroded bolts at rudder?
Hard to tell from pics but... How about a thin reciprocating saw blade between the "yoke" and the stub? Cut through the bolts and then drive them out when you withdraw the stub. It might sacrifice the surfaces between the two pieces a little but that can be fixed after they are apart. I have a small battery powered recip saw that has helped me through some difficult "blind" problems.
Down
Islander-28, Marshall Sandpiper
downeast450 is offline
post #12 of 12 Old 05-10-2013
It lookis like the nuts are off, but the bolts are still stuck in their sleeves?
PBlaster and a big wrench, or a nut splitter if needed, to remove the nuts. Then use a c-clamp to press the bolts out of the sleeves if need be. Once they start to move you should be able to tap them out.
A small maul, deadhammer, or similar can be a great tool in a restricted place like that.
hellosailor is offline
Tags
bolts , corrosion , removal , rudder
Removing old/corroded seacocks Beersmith Gear & Maintenance 16 03-24-2013 07:35 PM
Advice on removing snapped s/s bolts from alu block MarkSF Gear & Maintenance 35 10-08-2012 07:28 AM
Removing lag screws corroded on strainer thruhull Goblinfog Gear & Maintenance 1 03-28-2011 03:34 PM
Removing the rudder Survivor Gear & Maintenance 4 08-08-2008 12:37 PM
Tips for removing Cetol? Quickstep192 General Discussion (sailing related) 11 03-10-2007 06:02 PM
