Dry bilges - Page 4 - SailNet Community
 3Likes
post #31 of 38 Old 05-10-2013
Senior Slacker
SlowButSteady's Avatar
Re: Dry bilges
I just remembered that it used to help to set a sponge on the end of the twine/wick/siphon that was in the bilge. It kept the twine from moving around (and/or falling out of the bottom of the boat), and it seemed to drive the whole siphoning process to completion a bit better than without the sponge. Also, if I recall correctly, I used pretty heavy twine; probably closer to the cotton clothesline that others have mentioned than kitchen/butcher's twine.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #32 of 38 Old 05-11-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Dry bilges
even if the wick didn't pull water into the lower part of the bilge, it would help to dry it out. The water being pulled up into the wick would have more surface area to the air, and would evaporate quicker
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #33 of 38 Old 05-11-2013
Tartan 27' owner
CalebD's Avatar
Re: Dry bilges
I have seen a chamois cloth (or Sham-wow) used for this purpose. This kind of cloth allows amazing capillary action with water. The starting and ending points would need to be secured somehow.
Everybody has one:
CalebD is offline
post #34 of 38 Old 05-11-2013
Re: Dry bilges
Originally Posted by Minnewaska View Post
I can't readily tell the difference between these two. Is there a significant difference, I'm not seeing?
I couldn't tell the difference between the venturi's...on the Mazzei site they have the tech specs, but it's a bit beyond my reading comprehension level...
I stumbled on the the idea from this thread: sailnet.com/forums/gear-maintenance/32519-ac-condensate-drainage.html {You have to put in the 3W's in front of sailnet there all by yourself because I don't have enough posts yet to post links...sorry}
There are a couple other of other ideas in that thread that might work for your situ, but they aren't quite so Sham-wowzing as the ideas in this thread....
67Therapy is offline
post #35 of 38 Old 05-11-2013 Thread Starter
Re: Dry bilges
Hadn't seen the link. Turns out the Mermaid condensator is a kit that essentially does this. $170 at defender, but the venturi were $80 or $90 alone and I have to source tubing, filters, etc. Still, I'm thinking the Arid Bilge pickup is the trick. I can not find where to buy those online at all.
Jeanneau 54DS
Minnewaska is offline
post #36 of 38 Old 05-11-2013
Commodore
n8kraft's Avatar
Re: Dry bilges
I'm a fan of using diapers to get water out of hard to reach parts of the bilge. I've got a baby on the boat so there are plenty of diapers available and they're super absorbant. You could even use the velcro to secure it around the base of the mast.
Invest in experiences, not things.
Sailing with Nate, Natalie and Sullivan at
n8kraft is offline
post #37 of 38 Old 05-11-2013 Thread Starter
Re: Dry bilges
Real diapers, bad memories.
Jeanneau 54DS
post #38 of 38 Old 05-11-2013
Re: Dry bilges
why do I have images of a mast in diapers now?
Art Haberland
Bilges - On vs. Automatic; Capacity? dvuyxx Gear & Maintenance 23 01-22-2013 05:07 PM
Two Bilges columbia 10.7 Columbia & Coronado 3 12-18-2011 12:19 AM
Berths, WCs and Bilges hrt SailNet FAQ 3 11-03-2011 07:08 PM
Frozen bilges Minnewaska Gear & Maintenance 15 01-25-2011 03:28 PM
Cleaning nasty greasy bilges? Zogumwesterly Gear & Maintenance 32 08-25-2009 01:43 PM
