Old 06-17-2004
pma_foyl is on a distinguished road
Deisel Rear Main Seal
I''m already afraid to ask this question, but if anyone with similar experience could give some insight, I''d really appreciate it.
I have a Westerbeke 60 (old) with "suspicious oil leaks" which appear to be from the bottom of the engine about "mid-engine." I''m not sure yet (and praying that I''m wrong) but I suspect the rear main seal may be failing.
My questions ...
What else might be producing an oil leak near the bell housing?? Oil pan? Any way to determine (since I can''t see under the engine - no space).
It leaks about a tea spoon an hour (while running). Is this really excessive? Should I be concerned that the entire seal could give way at any moment? Would this instantly seize my engine?
What is the "real" risk with adding oil to an "uncertain" quantity currently in the engine? I''ve heard people say, too much oil with "blow the seals out." What''s too much oil? An extra pint? An extra quart? what??
What should it cost to have an engine pulled and the seal (and associated parts) replaced??
Any help would be great. Thanks.
Old 06-22-2004
paulmcquillan is on a distinguished road
You may want to contact the people at
http://www.marinedieseldirect.com/ which is a discussion group with archives.
It''s run by the diesel experts at Torresen Marine
http://www.torresen.com/
If you get any feedback on some of your detailed questions, I''d be interested in reading what they have to say.
slugs catching upon raising main remazerov Seamanship 24 09-04-2006 07:03 PM
Packless Shaft Seal (PSS) bkdehuff General Discussion (sailing related) 4 04-20-2004 05:41 PM
Rear Seal Replacement tm3 Gear & Maintenance 2 01-07-2004 03:30 PM
main halyard Sailmale Gear & Maintenance 5 06-20-2002 09:25 PM
recutting my blown out main jollymonjeff Seamanship 6 12-27-2001 09:38 AM
