Yanmar mounted on Volvo Bed - SailNet Community
post #1 of 22 Old 05-10-2013 Thread Starter
I have a low hour Yanmar 3gm30f w/sd20 that I would like to install on my Volvo MD11 engine bed. Has anyone done this job? I know Beta makes custom feet to fit an MD11 engine bed, but I can't find anything information about Yanmar mounts.
I have a few options, but I'd like to hear from anyone who has made this change.
Options are:
1. Find proper Yanmar Engine/saildrive bed - ($1200 is too much at the moment)
2. Find custom feet to fit the old Volvo bed.
3. Customize old engine bed somehow to make the Yanmar fit.
Any help/info is appreciated.
Freerider is offline
post #2 of 22 Old 05-10-2013
Re: Yanmar mounted on Volvo Bed
We changed out an Atomic gas engine to a Volvo some years back.. the beds were at a different angle and spacing than the Volvo required. As the beds were wider, we cut them down to the correct angle, and installed fairly heavy Aluminum 'angle iron' inside each bed to achieve the correct spacing. In the end it worked out fine, but was a bit of a nasty job, esp the cutting of the solid beds.
Anything is possible with enough ingenuity and courage!!
Faster is online now
post #3 of 22 Old 05-10-2013
Dog Ship's Avatar
Our boat used to have an A-4 and it now has a 3gm30f.
Two large pieces of angle iron were bolted to the old fiberglass runners and some after market engine mounts were used to mount the engine. The mounts offer a bit of adjustment for alignment. Seems to work quite well, with little to no vibration.
I've put Chevy engines in Fords, so anything is possible.
We have three rules;
No screaming.
No bleeding on the sails.
No slobbering on the charts.
Dog Ship is offline
post #4 of 22 Old 05-10-2013
Have a go and DIY .....
Options are:
1. Find proper Yanmar Engine bed - ($1200 is too much at the moment)
ANY metal fabricator will be able to make the new brackets to fit the yanmar engine and mountings to fit the engine bed..
After all it is just a case of making 4 l shaped brackets.....
macwester26 is offline
post #5 of 22 Old 05-10-2013
overbored's Avatar
not sure I under stand what you are planning. you are swapping in a yanmar with a SD20 sail drive and you currently have a volvo on a SD20 sail drive?
"GOLD RUSH" PRINDLE 16
overbored is offline
post #6 of 22 Old 05-10-2013
... Oops.... missed that part.. changing to a saildrive from shaft/strut? Adapting to pre-exisiting SD? Much different job!!
post #7 of 22 Old 05-10-2013
Dog Ship's Avatar
Oh, sorry I missed the sd part of the question. Thats a whole different ball game. I don't know if a yanmar will bolt up to a saildrive? It may require a bellhousing adapter.
Never been a big fan of saildrives.
No screaming.
Dog Ship is offline
post #8 of 22 Old 05-10-2013 Thread Starter
Sorry I didn't explain enough.
I removed a Volvo MD11c w/ 110s sail drive and now I'd like to install a Yanmar 3GM30F w/ SD 20 saildrive.
I'd just really like to make it work without forking out a bunch more cash. My departure date is less than 90 days away and I'm starved for $$.
I'll try and post a picture of both beds.
post #9 of 22 Old 05-10-2013 Thread Starter
Here are the 2 beds side by side, Volvo on the left Yanmar on the right.
I'm back and forth on how to make this work, so i was just hoping someone else has already done this. I'll have to drill and tap new holes for the saildrive but I should be able to make that part work. Its the engine feet I'm having troube with.
post #10 of 22 Old 05-10-2013
So.... you're grinding out the old bed, reglassing in the new? or trying to mate the new drive with the old bed? If the latter, I dunno... looks like different SD bolt pattern and even a different sized hull cutout..
Could be a challenge..
Deck mounted versus keel mounted masts VetMike Gear & Maintenance 35 02-17-2012 09:59 AM
Volvo MD17D Mounted on Down Angle? kc_cmc Diesel 0 01-10-2011 11:57 AM
Yanmar vs. Volvo bobwebster Diesel 3 10-30-2009 06:56 PM
volvo vs yanmar fly452 Boat Review and Purchase Forum 3 10-17-2003 10:20 AM
Volvo to Yanmar SailDJ Gear & Maintenance 2 07-01-2002 06:44 PM
