3M Marine High Strength Repair Filler - Page 2 - SailNet Community
 6Likes
post #11 of 13 Old 05-13-2013
Senior Smart Aleck
jameswilson29's Avatar
Re: 3M Marine High Strength Repair Filler
Wow, you are right. The label on the can reads "Fiberglass Resin" and, upon checking the ingredients, I see polyester resin. Thanks for the education. I need to learn to read ingredients more closely before shooting off my mouth.
Now I have to eat my smart aleck comments, along with my hat.
brokesailor and jimgo like this.
jameswilson29 is offline
post #12 of 13 Old 05-14-2013
Senior Moment Member
SloopJonB's Avatar
Originally Posted by miatapaul View Post
Yes, 3M makes good products, but I can't see filling a 3 inch by 5 inch hole without using some glass if you expect there to be any strength. I once upon a time filled holes about that size with bondo on a fender and it did not last long! Perhaps a screw hole, but not a big opening like 3X5. I think one good kick and it will pop out or at least crack.
Missed that bit.
Definitely can't fill a big hole with filler.
SloopJonB is offline
post #13 of 13 Old 05-15-2013
pauloman's Avatar
google Wet Dry 700 - it is a kevlar - feldspar reinforced epoxy paste that can even be applied underwater. (has saved a number of sinking boats and leaking swimming pools)
pauloman is offline
Tags
fairing , fiberglass repair , filler , repair , vinyl ester
High Priced "Marine" Thermostats dbruce85 Gear & Maintenance 10 04-09-2013 08:56 PM
using 3M marine premium filler muskoka.sailor Gear & Maintenance 21 06-17-2012 12:35 PM
marine hand pump high and dry bornagainsailor General Discussion (sailing related) 4 06-28-2011 09:13 PM
Gary; Very good Marine Transmission repair referral NewsReader Mass Bay Sailors 0 06-27-2007 01:15 AM
NorCal Marine Sanitation Install/Repair? Fstbttms Gear & Maintenance 2 04-28-2007 12:26 AM
